console lights flicker - Jeep dies when cold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > console lights flicker - Jeep dies when cold
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread 09-27-2014, 03:50 PM   #1
clcrump
Everyone, my 2002 wrangler has been dying when I first start it and it runs at idle. The console lights flicker sporadically and then it just dies. Once the car is warmed up - to say 200 degrees, it does fine - even at idle. I've cleaned the Idle Air Control and the intake manifold. I don't think its the IAC. I think its an electrical problem because of the console lights flickering - any suggestions? On a side not, I'm not a mechanic, but I can do most small mechanical jobs on my own.
Curt
clcrump is offline   Reply With Quote Quick reply to this message
Unread 09-27-2014, 05:56 PM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The first thing i'd try is remove both battery connectors and wire brush the battery posts and inside of the connectors until they are bright and shiny clean. Then reinstall them and tighten them securely enough so they can't be moved/rotated by hand. You can buy a wire battery cleaning brush for $3-4 that has both the male and female brushes needed to clean the posts and connectors.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 09-27-2014, 06:31 PM   #3
clcrump
Okay. Thanks Jerry. I'll try that first.
