Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? - JeepForum.com
post #1 of 35 Old 02-10-2011, 08:54 AM Thread Starter
ezgoin
Ok , so here is the dilemma, We have a 2001 sahara stock 3 spd auto were getting ready to upgrade to 8.8 rear axle ,4.56 gears, front hp 30 with 4.56 gears. Plan on 35 " tires with a clayton 5.5" lift.as well as upgrading brakes and steering to currie components.
Where we get confused after hours on this forum is why do people run 4" lifts plus body lifts when you could just do the 5-5.5" suspension lift and run 35's? Is the change in center of gravity that much different, will we really notice the difference?
We wheel what ever comes our way rocks,mud ,trails ,will try just about anything at least once.But still drive it around town as well as highway.
Have heard nothing bad about the clayton and have decided we want a long arm for ride issues on highway.
We are torn between the 4" clayton and the 5.5"
So if I could get some reasons why people go one way or the other that would be great . Thanks
ezgoin is offline
post #2 of 35 Old 02-10-2011, 09:00 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
BL's open the door for other mods and most people run SA 4" lifts.Anything over 4" on SA's would ride like crap.
TheBoogieman is offline
post #3 of 35 Old 02-10-2011, 09:02 AM Thread Starter
ezgoin
What type of mods are you referring too that you can do with a bl that can't be done with a suspensiojn lift?
ezgoin is offline
post #4 of 35 Old 02-10-2011, 09:04 AM
biffgnar
biffgnar's Avatar
Originally Posted by TheBoogieman
BL's open the door for other mods.
X2! Getting that tummy tucked up tight one of the most effective mods out there.
Romney in 2020!
biffgnar is offline
post #5 of 35 Old 02-10-2011, 09:05 AM
TheBoogieman
Disturbed
Most TT's and it makes a MML slightly easier.Plus the BL doesn't make the driveline angles worse and gives you better clearance.
post #6 of 35 Old 02-10-2011, 09:13 AM
ohtenwillys
If you wanna talk center of gravity, a 5.5" isn't a good idea
ohtenwillys is offline
post #7 of 35 Old 02-10-2011, 09:13 AM
bombman0513
True,, the body lifts allow room for growth...Some say you need them for the MML, others not so much, mostly for the fan shroud etc. You can get into a larger fuel tank etc etc... I would do the 4" on the suspension, and go for the 1" BL just in case while you are under there to give yourself room with the 5". Put on some higher clearance fender flares, etc. 4" seems to be the magic number. If you do the 5.5 with the 1" you are pushing the limit on the lift and getting into other necessary mods to get your angles and geometry where it needs to be for best performance. (CV driveshaft, transfer case drop, MML, bump stops, longer shocks, coil spring retainers, sway bars, on and on it goes.. Good choice on the Currie components and LA lift. I love my antirock, currectlync, and Rock Krawler 5.5" LA lift (w/ all the mods to get everything else back into alignment). Longgg story short,,the higher you go,, the more $ you are looking at.
"THE ONLY DIFFERENCE BETWEEN YESTERDAY, TODAY, AND TOMORROW IS....YOU'VE ALREADY LIVED THROUGH YESTERDAY"
bombman0513 is offline
post #8 of 35 Old 02-10-2011, 09:18 AM
Imped
Imped's Avatar
You do realize there are no rules to this stuff, right? You don't NEED 4" of lift to run 35's. You definitely don't need 5.5". I run 35's on 2.5" of lift with a 1" body lift. I'll bet I have as much shock travel as you'll have with your 5.5" of lift, a lower center of gravity, and the same or more belly height. I use the body lift solely for tucking purposes. I run a flat transfer case skid plate and a tucked gas tank. 20" under the belly and 18" under the gas tank.
OlllllllO
IndyORV
Imped is offline
post #9 of 35 Old 02-11-2011, 05:06 PM Thread Starter
ezgoin
So has anybody ran the full aev 4" kit or just used different parts from it ?
ezgoin is offline
post #10 of 35 Old 02-11-2011, 05:08 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
An Avenger supercharger!
GOLENJEEPTJ is offline
post #11 of 35 Old 02-11-2011, 05:10 PM
GOLENJEEPTJ
"Lighten up Francis"!
post #12 of 35 Old 02-11-2011, 05:23 PM
rondak46
Gotta say, Thread titles like "confused" don't do it for me. Please put some info in your titles.
rondak46 is offline
post #13 of 35 Old 02-11-2011, 07:02 PM
Talton
get metalcloak fenders and run 35's
Talton is offline
post #14 of 35 Old 02-11-2011, 07:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A TJ with a 4" suspension lift plus a 1" body lift has a slightly lower center-of-gravity than a similar TJ with a 5" suspension lift yet it has the same tire clearance.
Jerry Bransford is offline
post #15 of 35 Old 02-11-2011, 09:06 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
And works well with 35" tires...
Knuckelhead is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 09:19 PM
Confused body lift vs. suspension lift spillz TJ Wrangler Technical Forum 10 10-09-2007 10:31 AM
i have a 4"suspension lift and my 35's fit fine why do i need a body lift?? bumblebee92gt TJ Wrangler Technical Forum 6 01-20-2005 07:50 AM
