Confused about backspacing and overall wheel size (What backspacing for a TJ?) - JeepForum.com
post #1 of 22 Old 03-23-2009, 08:00 PM Thread Starter
uknowwho
I tried to do a search, but I think I'm just confusing myself more. What would fit better on a stock 1997 Wrangler Sport? I am looking at these...
CRAGAR Wheels Black Rock Series 952 Street Lock Steel Wheel in Matte Black... and will probably get a set of BFG Mud Terrain tires.
I don't understand all of this backspacing stuff. The sizes I am looking at are...
15x8 with 3.75 backspacing
15x8 with 4.75 backspacing
15x10 with 3.75 backspacing
Is anyone running these wheels on a TJ? If so, pics would be appreciated.
uknowwho is offline
post #2 of 22 Old 03-23-2009, 08:13 PM
diy4x4
2007 MK Patriot
Check out this link from 4x4xplor. It might help http://www.4x4xplor.com/rockcrawlers.html
diy4x4 is offline
post #3 of 22 Old 03-23-2009, 08:16 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
The shallower the backspace, the farther out the rims are.
What size tires are you going with? If you're looking at something around 12" then you will want a shallow backspace. It'll keep the tires from rubbing on turns and it'll make you more stable. But, remember that PA requires the flares to cover the full tread of the tire. So factor either the price of wider flares or consider narrower tires and keep the stock 4.75 backspacing.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #4 of 22 Old 03-23-2009, 08:17 PM
otisdog
2008 WK
15 x 8 with 3.75 is the best choice. The backspacing determines how much clearance there is between the tire and Jeep components - in other words how far the tire is moved out. This is quite important with bigger wider tires to deal with rubbing issues. Stock backspacing is 5-5.5" which has the tire in much closer to the spring perchs etc.
8" wide wheels will hold the bead better than 10" when you air down on trails.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 22 Old 03-23-2009, 08:19 PM
2005X
Jim
x2.............
2005X is offline
post #6 of 22 Old 03-23-2009, 08:30 PM
Parish
Are cragar soft 8's available with a 3.75 backspacing?
Parish is offline
post #7 of 22 Old 03-23-2009, 09:24 PM
2005X
i couldnt find any so i went with "4
2005X is offline
post #8 of 22 Old 03-23-2009, 10:38 PM Thread Starter
uknowwho
Thanks for the replies... now I understand. Basically backspacing gives you more turning clearance for wider tires.
uknowwho is offline
post #9 of 22 Old 03-24-2009, 07:15 AM
2005X
right, so you wouldnt want a 12.5 wide tire with "5BS cause you rub like crazy.
2005X is offline
post #10 of 22 Old 03-30-2009, 08:35 PM
scott33
33x10.5
So if I were running 33x10.5 the 8" rims with 3.75 backspacing would be sufficient?
scott33 is offline
post #11 of 22 Old 03-30-2009, 08:53 PM
2005X
yup............
2005X is offline
post #12 of 22 Old 07-29-2009, 05:53 PM
emayer32
i know im kind of bringing this back from the dead but why is 5" back spacing less then 3.75". less is more?
emayer32 is offline
post #13 of 22 Old 07-29-2009, 05:57 PM
Keith_C
It pretty much equates to a negative value, so yes less is more.
Less backspacing means more sticking out.
Keith_C is offline
post #14 of 22 Old 07-29-2009, 05:59 PM
Rubi Unlimited
The spacing is on the back of the wheel. Less spacing means the rest of the wheel sits more outboard. More backspacing means the wheel will sit more inboard. As I understand it.
Cleverly disguised as responsible adult.
Rubi Unlimited is offline
post #15 of 22 Old 07-29-2009, 06:14 PM
emayer32
duh. i get it now you measure from the hud to the inside of the jeep the backspacing is that number so of course you put spacers on the number becomes smaller see not as dumb as i look.
edit: Thank you for your help
emayer32 is offline
Tj owner confused about which backspacing and wheel size to choose! help!! rc_007 TJ Wrangler Technical Forum 7 11-11-2008 06:16 PM
Spare on different size/backspacing wheel? itasor TJ Wrangler Technical Forum 1 09-15-2008 09:32 PM
Correct aftermarket wheel size/backspacing? Hotprowl JK Wrangler Technical Forum 7 09-09-2008 08:29 AM
Wheel size/backspacing for JK? red7 JK Wrangler Technical Forum 14 06-19-2007 10:57 AM
Wheel size and backspacing bulldawg747 TJ Wrangler Technical Forum 6 08-01-2004 05:26 PM
