Condensation inside of jeep - JeepForum.com
post #1 of 8 Old 11-20-2009, 06:42 AM Thread Starter
xkuzme1
The last two mornings I have went out to my jeep to find condensation inside the jeep. There is enough condensation that it puddles and dropped from the inside of the hard top. This is my first TJ with a hardtop.
Is this normal? My soft tops on previous jeeps have never done this.
X
JEEP - The original "search engine".
Ask me why you should not buy anything from 4 Wheel Online
xkuzme1 is offline
post #2 of 8 Old 11-20-2009, 07:01 AM
Boodyrider
Nope. You almost certainly have water under the carpet from offroad adventures, a leak somewhere, or a leaking heater core.
Lift the passenger side carpet and see how wet the insulating pad is.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #3 of 8 Old 11-20-2009, 08:14 AM
LJinNOLA
X2 on water inside somewhere. How long have you had this jeep and hard top? Does it feel muggy when you get in, especially after being in the sun?
2004 LJ. OME 933/942 JKS BL, Brown Dog MML. Homemade Trunk, Snorkel, Lined Tub.
LJinNOLA is offline
post #4 of 8 Old 11-20-2009, 09:07 AM
amike_321
Mine did this for weeks after I got rained on with the top off. Put the hard top on and whamo, drops falling from the inside of the hardtop. Leave the windows cracked for a few days, run the heat, or put a fan on the carpet at night to dry it up.
amike_321 is offline
post #5 of 8 Old 11-20-2009, 09:25 AM
Mick VT
Mick VT's Avatar
Add or a blocked A/C drain to that (even if you are not "using" AC - it comes on with defrost)
Mick VT is offline
post #6 of 8 Old 11-20-2009, 09:44 AM Thread Starter
xkuzme1
Yes that makes perfect sense. I have a leaky seal in the window. I have been trying to locate the exact source of the leak for quite some time. I have siliconed the outside of the windshield but it still leaks (drivers side top). I thought that my Husky Molded floor liners were catching all of it, but I guess not.
Thanks
X
xkuzme1 is offline
post #7 of 8 Old 11-20-2009, 09:59 AM
GeoKR
please do not put silicone on the windshield. windshields are glued in with urethane, silicone will not stop the leak, it may fix it for a while but the silicone will not bond with the urethane and it will start leaking again. you can pick up some urethane at your local glass shop, or just have them do it. I was born and raised in the glass business and we own several shops from Texas to Louisiana and I typically charge about $45 to find and seal leaks in the windshield.
98 Sahara 4.0 5spd - 5" W/ 35" Boggers, Rubi 44 Front Locked & Chromo'd w/ 5.13's, 8.8 Rear Locked w/ 5.13's, NV241OR, Woody Shafts, Flat Skid, Tuff Designs Front Bumper, EPi9.0 W/ Blue steel
I spent most of my money on women, booze, and toys, the rest I just wasted.
GeoKR is offline
post #8 of 8 Old 11-20-2009, 10:03 AM
Roye77
2011 JK Wrangler
OMG just say no to silicone!!! Please once you use silicone on something nothing else will ever stick to it again and it causes rust.
"All men are created equal, then a few become firemen." ~Author Unknown
"Volunteer firemen do it for free!" ~Author Unknown
Roye77 is offline
AC Condensation when not using AC knotcher TJ Wrangler Technical Forum 5 02-22-2007 05:52 PM
Condensation inside soft top this AM quigtj TJ Wrangler Technical Forum 12 08-16-2006 01:27 PM
condensation under oil cap dunney TJ Wrangler Technical Forum 7 01-07-2006 04:25 PM
Condensation? Jeep_Maniac TJ Wrangler Technical Forum 2 11-06-2005 01:06 AM
'05 AC Condensation SMACC TJ Wrangler Technical Forum 10 06-16-2005 02:47 PM
