Condensate draining into floor - JeepForum.com
post #1 of 3 Old 07-11-2010, 08:24 PM Thread Starter
Nuge
I've noticed recently that I have my AC condensate draining into the passenger side floor. Is there a hose that has come undone, or is their a different problem? If it's a hose, where is it? Any thoughts?
Nuge
66 Scout 800
05 F350 Super Duty
05 TJ Unlimited
Nuge is offline
post #2 of 3 Old 07-11-2010, 08:54 PM
andy02
It is one of two possibilities.
A) The condensation drain under the cowl is clogged. You can run a coat hanger through it to clean it out.
B) The condensation is due to the poor design of the condensation drain itself. Fix is here: http://www.stu-offroad.com/body/ac/acleak-1.htm
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #3 of 3 Old 07-11-2010, 09:12 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Sounds to me that your condensate drain is clogged and is overflowing into the compartment. The drain is in the engine compartment (firewall) and you will need to clear it out.
Dirt gets into it via the air cowl.
I thin that the pic shows the correct spot for the drain.
Group W Bench
CRAWLING 98 is offline
Leak , passenger , floor , a/c , hose
While I was draining my oil... Jeepster83 TJ Wrangler Technical Forum 6 06-10-2009 08:58 PM
A/C is draining into passenger floor pan... kbarwall TJ Wrangler Technical Forum 7 08-08-2008 08:17 PM
A/C Condensate Drain Extension quailrunfarm@ve TJ Wrangler Technical Forum 0 06-25-2008 03:24 PM
Carburator draining chapin14 YJ Wrangler Technical Forum 9 02-24-2005 01:14 PM
BA-10 draining jamerkel YJ Wrangler Technical Forum 5 02-20-2004 09:09 PM
