Compressor Mounting - JeepForum.com
post #1 of 12 Old 12-26-2005, 11:23 AM Thread Starter
penguinland
penguinland's Avatar
Compressor Mounting
I just got a Viair 280c and I am looking for ideas of where others have mounted theirs. I am leaning towards laying it sideways under the driver seat. Pics would be great. I hope everyone had a great Christmas !
2004 WJ 4.0
2" BDS springs + 3/4" spacers up front , Goodyear Duratrac 245/75R16, Yaesu FT-7900R
penguinland is offline
post #2 of 12 Old 12-26-2005, 11:33 AM
FifteenCents
In the engine compartment
under the brake booster, there is a plate that is not used for anything (at least on my 97) it is protected from most damage.
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #3 of 12 Old 12-26-2005, 01:24 PM
kizer
kizer's Avatar
Check this out.
http://www.moabjeeper.com/viairinstallreview.htm
1600+ Write-ups, and more
kizer is offline
post #4 of 12 Old 12-26-2005, 03:08 PM
98TJSport
that is a good spot, if he dosnt have cruise. thats where that is if he does.
==KF7HBV==
2004 TJ X
98TJSport is offline
post #5 of 12 Old 12-26-2005, 04:29 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I have cruise, and I mounted my compressor on that plate under the brake booster without a problem. The cruise vacuum motor is mounted higher and more forward on the wheel well.
I'll be Savvy someday!
neZZr is offline
post #6 of 12 Old 12-26-2005, 04:44 PM
Spartan302
Spartan302's Avatar
I believe the abs equipment gets mounted there under the brake booster.
I would mount it under the seat.
Spartan302 is offline
post #7 of 12 Old 12-26-2005, 04:48 PM
neZZr
neZZr's Avatar
In his case maybe, as it looks like he may have had the D35 before swapping in the 8.8... but not all TJs have ABS.
neZZr is offline
post #8 of 12 Old 12-26-2005, 05:00 PM
Spartan302
Spartan302's Avatar
I know all don't (i should of typed that more clearly, now that I read back over it). Mine doesnt. Just those that have abs I'm pretty sure that is where it is. Just clearing it up that it isn't the cruise control equipment.
post #9 of 12 Old 12-26-2005, 07:03 PM
98TJSport
ok then i was mistaken, i just know on my friends jeep he dosnt have any room there, and he has cruise. i thought thats what it was.
==KF7HBV==
2004 TJ X
post #10 of 12 Old 12-26-2005, 08:10 PM
neZZr
neZZr's Avatar
I wish I had a better picture... just found this on google.
The vacuum motor for the cruise control is the little black/silver can with the cable coming from it sitting just behind the washer bottle, on top of the wheel well.
The ABS tray is just below the master cylinder.
Hope this helps!
neZZr is offline
post #11 of 12 Old 12-26-2005, 09:43 PM
98TJSport
here are some pics that i just snaped of mine
==KF7HBV==
2004 TJ X
post #12 of 12 Old 12-27-2005, 06:04 AM Thread Starter
penguinland
Thanks everyone. I don't have abs or cruise so that plate is available to me. Now I just have buy a tank and all of the tubing.
2004 WJ 4.0
Mounting air compressor in engine bay stadleroux TJ Wrangler Technical Forum 18 04-26-2008 04:15 AM
Second best mounting location for ARB compressor? Bandicoot TJ Wrangler Technical Forum 9 02-24-2008 04:53 PM
Mounting Compressor PJCurry TJ Wrangler Technical Forum 16 01-20-2005 11:01 PM
Sanden Compressor Clutch work on a York Compressor? Stricken TJ Wrangler Technical Forum 2 07-14-2004 11:55 PM
arb compressor mounting? smittydog27 TJ Wrangler Technical Forum 1 05-18-2003 08:08 PM
