Is this the complete lift kit? - JeepForum.com
post #1 of 12 Old 11-11-2013, 11:48 AM Thread Starter
YellowJeepGuy
http://www.4wheelparts.com/Lift-Kits...fMTM3420-20013
What do you guys think of it?
YellowJeepGuy is offline
post #2 of 12 Old 11-11-2013, 11:54 AM
Lovinmyjeep
I think it's worth a try, especially for a daily driver with light offroad use I'm guessing...I had a kit like this before I got a bigger lift kit, I loved it, and It did exactly what I needed it to do, it was on my jeep for 5 or 6 years and help up great, I think mine was from performance offroad or something like that, but the kits like this are pretty much al lithe same I think
Lovinmyjeep is offline
post #3 of 12 Old 11-11-2013, 12:20 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
TrailMaster shocks do not last long based on my experience.
They do not ride very well either.
I'd look for a different brand budget Boost. Zone or Skyjacker with Hydro shocks are a couple better alternatives.
Wheelin98TJ is offline
post #4 of 12 Old 11-11-2013, 12:25 PM
RowJ
Agree.... Budget Boost HERE
RowJ is offline
post #5 of 12 Old 11-11-2013, 12:26 PM
Clarke2k
Clarke2k's Avatar
Fill in your profile so I know what year jeep you have.
It has everything for a 2" Lift.
Depending on your spring sag you may or may not get the full 2" lift
Clarke2k is offline
post #6 of 12 Old 11-11-2013, 01:38 PM
RowJ
RowJ is offline
post #7 of 12 Old 11-11-2013, 02:39 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by Clarke2k
Fill in your profile so I know what year jeep you have. It has everything for a 2" Lift. Depending on your spring sag you may or may not get the full 2" lift
But he will get 2" above what he already has. Spring sag has little to do when adding spacers.
Mail crawling.
MisfitSeven is offline
post #8 of 12 Old 11-11-2013, 03:29 PM
rda616
For a few bucks more you could have new springs and better shocks. I'm not a bb fan and would go a different route.
rda616 is offline
post #9 of 12 Old 11-11-2013, 03:53 PM
KP-J33PIN
What you see what the lift is what you will get in the box. As far as coil sag it is true that you will be higher but your front could look lower then the rear for instance if the front springs are worn compared to the back. Happened to me. Easy fix is to find a buddy with some Cherokee springs. I used a buddys (zj) the Ground weight of the Cherokee is more then a wrangler also so you will notice the difference immediately. Good luck!
-KP
" Why are you so sweaty?!?!"
" I was watching cops"
KP-J33PIN is offline
post #10 of 12 Old 11-11-2013, 04:38 PM
MisfitSeven
MAiL Crawler.
If his front looks lower than the rear adding 2" to all four corners will not fix the stock raked look.
Again, spring sag has nothing to do with the lift he is asking about. If he wants 3" up front and 2" in the rear, then he posted the wrong kit. He will get 2" above his current state with the posted kit.
I suggest the RC 2.5" kit. It's only $299.99. Save a little bit more.
Mail crawling.
post #11 of 12 Old 11-11-2013, 05:18 PM
rda616
This ^
rda616 is offline
post #12 of 12 Old 11-11-2013, 05:33 PM
Imped
Imped's Avatar
It's coil spacers and shocks. Whether that's "complete" or not depends on who you're asking. My answer--absolutely not.
OlllllllO
IndyORV
Imped is offline
lift kit
