Complete exhaust kits? - JeepForum.com
post #1 of 23 Old 02-26-2011, 02:25 PM Thread Starter
Zombi
The exhaust system on the heep is in desperate need of replacement.
I've been looking for a complete exhaust kit from the block back but havn't come up with a single kit that has everything.
Does anyone have any suggestions for where to find one?
Also I hear that the manifold on my 99 is prone to cracking, is there an upgraded manifold that doesnt cost an arm and a leg?
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #2 of 23 Old 02-26-2011, 03:11 PM
bhunter827
Not sure about engine size but this fits the 2.5
http://www.jeep4x4center.com/product...mber=52018933K
bhunter827 is offline
post #3 of 23 Old 02-26-2011, 03:17 PM
freeskier93
This:
Is the kind of header you want. It has the flex fittings (or whatever they are called) to help prevent cracking. The one pictured is a Mopar header, but cost about 500 bucks. There are some cheaper aftermarket one you can buy that are the same style.
freeskier93 is offline
post #4 of 23 Old 02-26-2011, 03:33 PM
Sundowner
x2...go with the later-style manifold. It works just fine, and flows just fine. Get a reputable local shop to run your exhaust.
Sundowner is offline
post #5 of 23 Old 02-26-2011, 04:04 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The "best" manifold you can get for your 99 4.0L TJ engine is the 2000+ 2 piece OEM one. You will have to have a "Y" pipe made...HTH
Knuckelhead is offline
post #6 of 23 Old 02-27-2011, 09:01 AM Thread Starter
Zombi
Will the 2000+ split manifold bolt right up to my block?
Since I'm looking to replace the entire system, couldn't I just run a 2000 exhaust system complete front to back?
Call me Z
Zombi is offline
post #7 of 23 Old 02-27-2011, 09:35 AM
Knuckelhead
AFSOC Retired
Yes it does.
Most 2000 exhaust systems have mini cats...
post #8 of 23 Old 02-27-2011, 10:09 AM
alextremetj
alextremetj's Avatar
If you have a local Napa around, you could always get the pre-made down pipe from them.
Part number : EXH 52317
It's from a 2000 TJ 4.0 WITHOUT Cali emissions.
alextremetj is offline
post #9 of 23 Old 02-27-2011, 10:18 AM
Knuckelhead
AFSOC Retired
http://cgi.ebay.com/ebaymotors/Walke...-/330534796234
Good find!...
post #10 of 23 Old 02-27-2011, 10:22 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I replaced my 98' 4.0 exhaust for $350 front to back.Ebay manifold with expansion joints($70) works great.Magnaflow direct fit cat with down pipe($140) and Flowmaster 40 muffler with tail pipe($140).
TheBoogieman is offline
post #11 of 23 Old 02-27-2011, 12:41 PM Thread Starter
Zombi
It looks like the 2000+ manifolds are cast, is that true and if so is that an advantage over tube?
Also, are the manifolds from a 2000+ cherokee the same as the wrangler version?
Call me Z
Zombi is offline
post #12 of 23 Old 02-27-2011, 01:47 PM
Knuckelhead
AFSOC Retired
Yes, cast.
Better because they don't crack like all the tube ones do...
post #13 of 23 Old 02-27-2011, 01:52 PM
BYuen
BYuen's Avatar
A good place to get the y-pipe with mini cats. I got this one when my mini cats went out. It's made by US company called Davico based in NJ IIRC.
http://jeep-car-parts.macautoparts.n...oductInfo.aspx
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is online now
post #14 of 23 Old 02-27-2011, 02:18 PM
Knuckelhead
AFSOC Retired
http://jeep-car-parts.macautoparts.net/Catalytic-Converters-5784/3919988-00-02-Wrangler-4-0L-Eng/ProductInfo.aspx
My 2000 Sport didn't come OEM with mini cats.
But thanks for the info...
post #15 of 23 Old 02-28-2011, 10:26 AM Thread Starter
Zombi
I just orderd a set of 2000+ manifolds with o2 sensors for $26 shipped.
So now it looks like I can get a complete exhaust kit for a 2000+ and be ok right?
Also, since the 2000+ looks to have o2 sensors in places my 99 does not, could I re-use the extra o2 sensors in my stock location? Would that throw codes or cause the engine to perform strangely?
Call me Z
Zombi is offline
Need a new complete exhaust for my 93 Pupuslinger YJ Wrangler Technical Forum 2 09-28-2010 08:09 AM
Complete polyurethane bushing kits Augy YJ Wrangler Technical Forum 7 01-19-2009 05:51 PM
TJ headpipe to complete my exhaust. Punisher YJ Wrangler Technical Forum 2 02-12-2006 01:31 PM
Complete Front End Rebuild kits? JzL YJ Wrangler Technical Forum 3 02-03-2005 08:21 AM
3" complete kits Savage4x4 TJ Wrangler Technical Forum 8 03-08-2004 09:34 PM
