Compass/Temp/Auto dim mirror swap (detailed with lots-o-pics) - Page 7 - JeepForum.com
 1Likes
post #91 of 182 Old 07-20-2011, 08:12 AM
99_TJ_Wyoming
for anyone who cant find one at a salvage yard, or, if like me, the closest salvage yard is 325 miles away, I got mine at amazon, a CIPA with compass, temp, auto darkening and map lights - http://www.amazon.com/CIPA-36500-Dimming-Rearview-Temperature/dp/B00029WSX6/ref=sr_1_2?ie=UTF8&qid=1311171068&sr=8-2
99_TJ_Wyoming is offline
post #92 of 182 Old 07-23-2011, 04:52 PM
GJR
[QUOTE=Slithering_Joe;11886953]You may need to hunt on the internet to verify the pin diagram for your application.
I was afraid of that but it wasn't as bad as I thought. Found some info on a forum called 12volt.com or something like that. Well see if this info turns out to be good.
GJR is offline
post #93 of 182 Old 07-24-2011, 02:41 PM
GJR
I ran the wiring harness from the mirror to the fuse box behind the glove compartment. Fuses 19 and 20 are labeled "spare fuses". Can I run the mirror through one of those or can I run it through any empty location and how do I go about doing that? I understand that the older TJ's have "accessory wire"s installed from the factory to use but mine being an '06 doesn't have that nice little feature.
Also, I have the temp sensor already installed from the factory. Does anyone know where its wiring harness goes to? I'm thinking that if I find the connecting plug, the plug upstream will have empty ports where the mirror wires would be if it was factory installed. I would just plug the wires from the #6 & 7 pins into those ports and it should work. Right?
GJR is offline
post #94 of 182 Old 07-25-2011, 07:33 PM
jeffjeep1
jeffjeep1's Avatar
If you have the sensor located on the left side of the grill openings, the other end will terminate under the trim piece just behind the windshield (the first pwice to remove if you are going to remove the center panel). There is a plug there for an additional connecting harness. I bought that harness and cut of the end at the mirror and grafted on the connector for the purchased mirror. The factory harness tucks nicely behind the passenger side trim along the winshield frame. A homemade harness would work too, but I had that particular harness left over from another project.
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #95 of 182 Old 07-25-2011, 11:22 PM
GJR
With my jeep being the "X" model, that harness is absent from my jeep, I already checked. I guess I should ask where that harness originates from. I followed the sensor wires to the firewall then ran out of time. I need to get under the dash and see where they go to next.
GJR is offline
post #96 of 182 Old 08-04-2011, 08:48 PM
GJR
O.K. The only empty buss in the fuse panel that had a switched lead to it was the rear wiper buss. Sense I have a soft top and no real plans to pick up a hard top, that's the buss I used. I picked up a terminal to plug into the accessory side of the #6 buss, grounded under the speaker and it worked. To answer my own question, the dual display and the single display have identical pinning in the back of the mirror.
I have yet to find where the temp sensor wires terminate so my temp display reads "OC", just like the OP said it would. Does anybody know where the harness (that I don't have) that's tucked under the dashboard trim plugs into? If I find that, I bet I find the end of the temp sensor wires. My guess would be somewhere by the steering column. Can the folks that have had the dash board taken apart shed some light on this?
Thanks. By-the-way, how do you post pics on this forum? Sorry, I know it's a dum a** question.
GJR is offline
post #97 of 182 Old 08-04-2011, 10:27 PM
N3KRV
I got the auto dimming mirror for my jeep for 5.00! and I found the pigtail to plug it in the light is a dim green.was wondering if that auto dimmer mirror has the temp and composs (sp) function?
N3KRV is offline
post #98 of 182 Old 08-05-2011, 08:28 AM
GJR
Nice price! If it has the comp/temp features, it should have the respective buttons along the bottom. Also, the pigtail will have 7 wires, if it's the GNTX-177 model.
GJR is offline
post #99 of 182 Old 08-06-2011, 09:44 AM
N3KRV
oh o.k. it don't have the buttons along the bottom of the mirror, and the pigtail I have is the one that was hidden up in the headliner, but the mirror has a place for another wire to be plugged in , later today I will go and see if I can find the mirror model number.
Thanks
Paul
N3KRV is offline
post #100 of 182 Old 08-06-2011, 11:52 PM
scot68
Originally Posted by 99_TJ_Wyoming View Post
for anyone who cant find one at a salvage yard, or, if like me, the closest salvage yard is 325 miles away, I got mine at amazon, a CIPA with compass, temp, auto darkening and map lights - http://www.amazon.com/CIPA-36500-Dim...1171068&sr=8-2
99 TJ Wyoming, How is this working out for you? Do you think the quality is as good (accurate) as an OEM unit? Was the install much different than retrofitting a OEM unit based on the discription above?
scot68 is offline
post #101 of 182 Old 08-10-2011, 07:37 PM
NickRicci
Ok I got the mirror for 16 bucks cool deal but in the process of install my stock mirror bracket glued to the jeep was half round shaped and the GM mirror excepted a wedge shaped bracket so I took the old one off and "tried" to add the wedge shape in its place. Well pushing on the windshield to set the glue is a bad idea, I broke the whole windshield. So now my mirror is going to cost 16.00+ 110.00 bummer but whatever. My question is this I was under the impression that the GM mirror and stock jeep mirror had the same shaped mount? Mine are different can someone tell me what shape or even better take a picture of their stock mount thats glued to their windshield? Because the guy on the phone thats coming to replace the glass tomorrow was like " I don't understand why its not stock....blah blah blah...we buy the windshields with the factory mounts already attached blah blah blah I don't understand...
NickRicci is offline
post #102 of 182 Old 08-10-2011, 07:46 PM
Dentedvw
I heard it ends up by the radiator, my temp sensor is down on the bottom, on the drivers side, between the radiator and the grille.
I can only give you what I think you said you thought you wanted.
Dentedvw is offline
post #103 of 182 Old 08-10-2011, 09:07 PM
GJR
No, I was talking about the harness under the trim piece by the windshield. I don't have that one and I was wondering where the end (that doesn't plug into the mirrors harness) plugs into.
I have a temp sensor by the grill and I tried to follow those wires and lost them after they went behind the inst. cluster. So then I thought I was just going to unplug the factory harness and make my own harness to plug into the factory sensor but when I did that, it threw a code. Researching this, I found that the factory temp sensor is also providing the CEM with info that allows it to provide appropriate air/fuel mixtures. I didn't know that and I've decided that messing with the factory harness is going to cause me more trouble than I can handle. So sense this mirror came out of a 2002 Yukon, I'm going to Chevrolet and getting the appropriate sensor and hopefully the pigtail. It doesn't look like I'll ever get to the salvage yard to hunt one down.
GJR is offline
post #104 of 182 Old 08-11-2011, 03:22 AM
N3KRV
I'm not sure where the pigtail of the temp sensor os, BUT the pigtail for the mirror power is under the headliner at the front endge by the windshield where the mirror os mounted, and to answer the other persons question my mirror mount had a round top, the flat side is facing downward towards the dash. I have a question what is the part called where the headlight adjusters are mounted in called and is it the entire part under the grill or is it in parts? like maybe 3 partleft, right and middle?s?? when I was changing the headlight shells on my Laredo I found the passenger side was all shatterd and unless I can just get the one side, I don't feel like taking the whole front grill area off, I'll have to go and do some creative engeeneering and make up a bracket to screw the parking light and turn signal lights to, I know they were trying to cut down on weight but geesh they could have left that part metal.
N3KRV is offline
post #105 of 182 Old 08-17-2011, 08:31 PM
GJR
Chevrolet couldn't help me if I didn't have a vin# and they didn't have pigtail for this application. So I made time to get to the salvage yard and picked up 6 sensors. If you reference the sensor pic from the OP on page 1, I picked up 2 of the "B" style, 3 of the "C" style and 1 that was similar to the "B" style but not the "A" style. Apparently, the "C" style give more acurate readings but I found that all 3 of mine read very high (120, 121, and 117). The weather channel says its 82, my home thermometer says 84 and my wife's van says 86. My "B" style sensors read 88 and 86 while the "other" sensor read 75. I'm using the the "B" style that read 86.
So I guess my point is if you pick one up at the salvage yard, get more than one or two and stick with the "A" or "B" style. I don't know whats up with the "C" style. I bet they're not compatable with the GTNX-177 because all three were high which makes me think something else is going on other than I got 3 bad sensors.
GJR is offline
Rear View Mirror with Temp/Compass? MusicMaverick TJ Wrangler Technical Forum 2 04-14-2008 04:44 PM
Mirror compass temp problem skruske TJ Wrangler Technical Forum 1 08-17-2007 06:08 AM
those with auto-dimming compass temp. mirror JeepMKcomin TJ Wrangler Technical Forum 14 04-19-2007 09:27 AM
Temp/Compass Mirror Hiccup? ironpony TJ Wrangler Technical Forum 5 11-09-2005 11:49 PM
temp/compass mirror? silverstone01 TJ Wrangler Technical Forum 5 10-08-2004 08:21 PM
