Color Changing Engine Coolant? - JeepForum.com
post #1 of 18 Old 04-11-2015, 08:10 PM Thread Starter
FireGuy1996
So I recently noticed that my coolant reservoir was completely empty, but my radiator was full with green, so I topped off the reservoir with NAPA green 50/50 pre-diluted antifreeze/coolant.
It was green coming out of the jug, but after checking it again a couple days later, its changed to almost a very light red, like watered down transmission fluid.
Is this supposed to happen or do I have a bigger issue with my radiator system?
My Jeep Build:
FireGuy1996 is offline
post #2 of 18 Old 04-11-2015, 08:15 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
did you know color is completely irrelevant?
you want to use the correct chemistry....otherwise you're playing a chemistry experiment with your cooling system. there are three main chemistries and they are not compatibility at all.
read these...
HOAT Coolant Summary
Brown in my radiator? Flush write-up
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 18 Old 04-11-2015, 08:53 PM
chris142
Did you mix a Long Life coolant with a conventional green? If so thats a contamination problem. All makes All models means long life coolants only not old skool greem with silicates.
chris142 is offline
post #4 of 18 Old 04-11-2015, 10:15 PM Thread Starter
FireGuy1996
I guess I will be flushing my radiator and reservoir. From what I hear its a pretty simple process, uncap the radiator and reservoir, loosen the drain cap on the bottom of the radiator, drain all the coolant, flush the rest out with a garden hose, then fill it back up with proper coolant?
Any suggestions as to what I should be using for coolant?
My Jeep Build:
post #5 of 18 Old 04-11-2015, 10:37 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
If you open the drain petcock without taking the radiator cap off, the coolant reservoir will be drained also...
Knuckelhead is offline
post #6 of 18 Old 04-11-2015, 11:08 PM
RDaniel2405
Instagram @theorangejeep
RDaniel2405's Avatar
Mopar 68048953AB, and distilled water
MY DAILY DRIVER BUILD
WTB Impact Orange half doors.
WTB Jeep JK Currie Front Track Bar CE-9120FJK.
RDaniel2405 is offline
post #7 of 18 Old 04-12-2015, 12:54 AM
SkeeterTZX
im wondering if you dont have a leak...either in your transmission cooler or a head gasket/head issue.
SkeeterTZX is offline
post #8 of 18 Old 04-12-2015, 09:01 AM Thread Starter
FireGuy1996
Why do you think that?
My Jeep Build:
post #9 of 18 Old 04-12-2015, 09:08 AM
centerfireman
Also, turn your heater to "high" (so that the coolant in the heater core gets flushed and drained also).
centerfireman is offline
post #10 of 18 Old 04-12-2015, 09:15 AM
Unlimited04
the heater setting on the TJ dash has nothing to do with fluid flow through the heater core itself.
Useful Write-Ups:
Funny:
post #11 of 18 Old 04-12-2015, 10:28 AM
GringoLoco
GringoLoco's Avatar
I'm far from a fully knowledgeable mechanic but I believe you want to get the engine hot enough to open the thermostat when flushing. Is that still necessary with our engines? I did to be safe but wasn't 100% sure it was necessary. I switched to the newer coolant so I really needed a full flush.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #12 of 18 Old 04-12-2015, 10:42 AM Thread Starter
FireGuy1996
Is my previous post about the process of flushing the system correct? That's what I heard is done on a JK, I'm not sure if its the same for a TJ.
My Jeep Build:
post #13 of 18 Old 04-12-2015, 01:17 PM
Shark_13
Unless you pull the drain plug in the block, there will be about 2 quarts left after the flush in the block.
Personally, I drain from the rad petcock, fill with distilled water, run motor up to temp to ensure thermostat opens and everything cycles. Drain and repeat until clear (3-4 times).
Once you are clear you know there is approx 2 quarts of distilled water in block. Do some math and figure out how much coolant to add to get a 50/50 mix.
I would be concerned with the red in the coolant, sounds like you have a leak.
Shark_13 is offline
post #14 of 18 Old 04-12-2015, 03:05 PM
mukluk
Your automatic trans Jeep in stock form has hoses routing the trans fluid through part of the radiator to cool the fluid, you may have a leak between those two parts. I suggest you check your trans fluid.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #15 of 18 Old 04-12-2015, 05:57 PM Thread Starter
FireGuy1996
That would explain the reddish tint. Any way I can check the hoses myself without pulling the radiator or do in have to disassemble the system?
My Jeep Build:
