Quantcast cold start problems and now spuddering at start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > cold start problems and now spuddering at start
Old 07-13-2008, 09:54 PM   #1
littledevilTJ
i had cold starting issues where it would crank for like 10 seconds and still not start, but second time i tried it would start right up..now its starting to spudder when it starts, like its missfiring and goes away after about 30 seconds..any ideas?
littledevilTJ is offline   Reply With Quote
Old 07-13-2008, 09:58 PM   #2
bigchevyman24
Sounds like you are having the fuel drainage issue. Where it's not holding pressure while off and draining out of the lines back into the tank. Try turning on the key for about 10 seconds before trying to crank it. You can search for it here. I can't remember exactly what it's called. Maybe someone else can chip it.
2000 WJ - I6, Auto, 2WD 2" BB, 18" JK wheels/32" tires, Converting to 4wd
---2WD TO 4WD CONVERSION---
97 TJ 4" lift, 35" boggers, lockright front D30, 9k winch - SOLD
95 XJ 33" TSL's, 2" BB, SEVERE trimming - SOLD
2003 WJ LIMITED PART OUT!!!!!!!!!
bigchevyman24 is offline   Reply With Quote
Old 07-14-2008, 06:15 AM   #3
Jonny Jeep
Jonny Jeep's Avatar
http://www.jeepforum.com/forum/f9/fuel-pump-problem-check-valve-518111/
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Old 07-14-2008, 10:51 AM   #4
littledevilTJ
thanks for the help. hopefully thats the spuddering problem too
Glock Forum
