cold start = loud squeaking noise - JeepForum.com
post #1 of 10 Old 12-28-2010, 07:02 PM Thread Starter
JeepJeepImABeep
When I start the jeep in the morning every day (it's like 15-25 degrees out now) it makes a very loud squeaking noise for a good 10 minutes until the engine heats up.
Sounds in tune, like it's a fan belt or serpentine or radiator belt or something.
Should I be concerned? Or is that normal.
It didn't make this very loud squeaking noise when it was warmer out.
JeepJeepImABeep is offline
post #2 of 10 Old 12-28-2010, 07:08 PM
MNakaChunks
Probably the serpentine belt, try tightening it a bit. The adjuster is right by the power steering pulley. Loosen the locking bolt/nut behind the bracket first.
- Michael -
MNakaChunks is offline
post #3 of 10 Old 12-28-2010, 07:08 PM
chadsmeltzer
chadsmeltzer's Avatar
Could be a belt, there is only one on a TJ so it's a quick easy change.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #4 of 10 Old 12-28-2010, 07:35 PM Thread Starter
JeepJeepImABeep
I sprayed WD-40 all over the fan too inside to see if it was the fan squeaking, but that didn't help.
If it is the belt, and I don't tighten it, will anything bad happen? or is it just an annoyance.
post #5 of 10 Old 12-28-2010, 08:24 PM
spreadneck
my 97 did this also,and i tightened the tensioner with a 9/16 i think and it solved the problem completely. the bad thing that can happen if your belt is as loose as mine got it could slip off track and throw everything out of whack,its an easy 2 minute fix
spreadneck is offline
post #6 of 10 Old 02-23-2011, 05:35 PM Thread Starter
JeepJeepImABeep
replaced the serp belt, still squeaking but not as much as before and not for as long. Still really annoying!
Ugh!
post #7 of 10 Old 02-23-2011, 07:27 PM
gabriel05
I had a similar problem with my jeep and it ended up being the tensioner pulley. I got a new one at autozone for $20 and that fixed it right up. Apparently the bearings were going out.
Black Jeep Society Member
gabriel05 is offline
post #8 of 10 Old 02-23-2011, 08:03 PM
bwright1818
Mine did this. It squeals mostly because the alternator is working its hardest at that point. I put on a new belt, thinking it was plenty tight but it still did it. Well, it seems like because of the belt routing on my '97, there really is not a lot of belt in contact with the alternator. I had to make the belt even tighter; but then I finally beat the noise. For the record, squeal equals wear.
bwright1818 is offline
post #9 of 10 Old 02-23-2011, 08:10 PM
chadsmeltzer
Could something be leaking on it? I had a slow coolant leak that was getting on the pulleys making them squeak.
post #10 of 10 Old 02-23-2011, 08:16 PM
Jeffro06
Jeffro06's Avatar
The oil pump drive assembly did this on my 2006 and it drove me nuts trying to find the source. Belt; nope, idler pulley; nope, alternator; nope. Then I learned about the 2005-2006 OPDA failures.
Does your jeep have an OPDA on it?
Jeffro06 is offline
Steering making a loud squeaking noise! ninjajeep TJ Wrangler Technical Forum 12 09-13-2009 11:18 PM
Extremely loud noise when I start 06 TJ in the cold? Jalec TJ Wrangler Technical Forum 35 02-05-2009 10:34 PM
Cold start Squeaking Noise from Engine. nsjeep TJ Wrangler Technical Forum 12 12-11-2008 10:44 PM
Loud tick on cold start but doesnt really go away... MPowerM3 TJ Wrangler Technical Forum 11 04-08-2007 09:20 AM
Loud screaching noise... start up JeepTransformer YJ Wrangler Technical Forum 13 11-17-2006 05:01 PM
