cold idling problems ? -
post #1 of 3 Old 07-31-2010, 10:08 PM Thread Starter
I cant figure out whats causing my 98 TJ, 6cyl, to run so rough when its warming up. If its been sitting for any period of time 30 mins or longer. while its going through its warm-up cycle, it runs horrible. Its stumbles, stutters, pops and rattles, it surges up and down almost like its gonna die out, but it doesnt. It does go away after about 10 min of idling. once it reaches its operating temp, its fine and it runs great. Its not showing any engine codes. I was kinda leaning towards some kinda sensor. I was thinking maybe the O2 sensor thats supposed to be on the Cat. I eliminated the Cat converter, but I did weld a threaded bong into a straight piece of pipe and I threaded the sensor back into that pipe, but Im thinking its not reading that sensor correctly until it gets hot, but thats just a guess.
any help would be greatly appreciated
96Smoke-Eater is offline
post #2 of 3 Old 07-31-2010, 10:19 PM
Hmm interesting, you chopped the cat. Did you try diconnecting the sensor with the bong" and starting it up? See if it maybe behaves the same momemtarily?
Is the bong smoking?
moonshinefuel is offline
post #3 of 3 Old 07-31-2010, 10:38 PM Thread Starter
No I havent tried that yet... thanks for the advice. its it a treaded bung? I dont know, but U know what I mean. I did get a chuckle at ur reply. Hey dont make fun of my Alabama education, LOL
cold , idle
In order to be able to post messages on the forums, you must first register.
sounds like trouble when idling, after cold start vzippa5 TJ Wrangler Technical Forum 3 11-06-2009 12:03 PM
1988 4.2 with problems idling mflave007 YJ Wrangler Technical Forum 7 03-28-2005 04:18 PM
idling problems tobrz YJ Wrangler Technical Forum 13 01-06-2004 05:59 PM
Problems Idling after Driving??? AllanAlxndr YJ Wrangler Technical Forum 3 12-03-2002 12:03 AM
idling problems crushnik TJ Wrangler Technical Forum 8 10-18-2002 09:41 PM
