Quantcast Cold air intake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Cold air intake
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 09-18-2009, 05:15 PM   #1
dking051
Cold air intake
Ok so here is a full write up on the cold air i did for my 2000 TJ. I did a bunch of research on how to do it, and finally decided to just do it. This is just one step closer to the hummer style intake which i just did not have time to do yet. So, I just did the filter in the cowl for now. It was quick and easy, maybe only took me an hour.
List:
AutoZone Cone filter: $20
AutoZone Ricer flex tubing $20
1 4" hose clamp (already owned)
2 2" hose clamps (already owned)
1 3" hole saw $16
Here is the stock motor
The inside of the cowl (cowl removed by 4 screws under windshield, 2 screws under weather stripping near hood hinges, and 1 screw in cowl intake opening)
Here is w/ the plastic cover over the A/C intake removed. I ended up having to cut off about the first 4" of this piece to make room for the filter. I made sure to leave the little lip so water could not get in.
First thing I did was figure out where the filter was going to go and traced it
Then I found center and tapped it
From the motor side in i drilled a pilot hole for the hole saw
It is always smart to measure 2WICE cut ONCE! no turing back now, cut a 3" hole making sure to avoid wires and the factory ground bolt
I decided to line the hole w/ small rubber tubbing that I slit down the middle to prevent the sharp edges from chaffing the tubbing that will go through it.
I then took out the stock intake (bolts are inside after you take out the filter)
I then took the flex tubbing I bought from AutoZone and I pushed it through the whole in the firewall, it just so happened to work out to where it actually threaded through really nicely and snug. I pushed about 3" through. Then I pushed the flex tubing into the filter and used a hose clamp to seal it. I then pushed it into place and it fits perfectly.
Here are a few pics to see the clearance.
I cut the flex end off of the stock intake and pivoted it to attach to the flex tube I already installed. I had to use a little black electrical tape around the stock tube where it was going to be clamped for a better fit. After clamping it on I reused the stock tube for the crank case vent, and hose clamped them on as well.
I think it turned out pretty clean for somewhat just winging it. I intend to do the full hummer style intake that popes out of the cowl at some point, this was just a starting point for now until I find a better filter system that I like.
dking051 is offline   Reply With Quote
Old 09-18-2009, 05:41 PM   #2
ninjajeep
Looks like you did an awesome job!
I would hate to have to remove the cowl, everytime I clean my filter.
'01 TJ 60th Anniv. Ed.
"6 cylinders of gut wrenching torque"
ninjajeep is offline   Reply With Quote
Old 09-18-2009, 05:50 PM   #3
kswyg001
2010 JK Wrangler
wow, there is a lot of room under the hood now!! my PO put in an underhood 'cold air intake' and it may go buh-bye.
kswyg001 is offline   Reply With Quote
Old 09-18-2009, 06:16 PM   #4
ModernJ
That should get a ton of cold air off the windshield. Nice looking set up. That would make room for a second battery where the air box was. What about water protection?
ModernJ is offline   Reply With Quote
Old 09-18-2009, 06:49 PM   #5
jknutter
www.theknutters.com
jknutter's Avatar
WIll you have to pull the cowl everytime the filter needs cleaning?
jknutter is offline   Reply With Quote
Old 09-18-2009, 07:00 PM   #6
sliseno
just a quick question on ths type cold air intake...would it be doable to just run a hose from the cowl to the stock airbox (say in the back of it) and remove the little snorkle and block off that hole? wouldnt that still be getting cold air. just an idea ive been tossing around. any thoughts?
Roads? Where were going, we don't need...roads!
sliseno is offline   Reply With Quote
Old 09-18-2009, 07:34 PM   #7
BC Jeep
Please post a picture of the cowl installed.
Did you use any kind of scoop over the vent area????
Bc
BC Jeep is offline   Reply With Quote
Old 09-18-2009, 07:41 PM   #8
JBTJ
I haven't done it yet, but when I do, that's the way I would. You can still use stock air filter which I think is better and compared to the OP's setup (nothing wrong with that) much easier to change the filter when need be.
JBTJ is offline   Reply With Quote
Old 09-18-2009, 09:27 PM   #9
Squint77
Very cool. Knowing that there is all that room under there gives me ideas. Did you feel any power boost? I notice in az my jeep gets more powerful when the temp comes down. It doesn't look like there is enough room to run
it further under the cowl and up the side of the windsheild unless you connect a flat type duct or come directly up throu the cowl. Keep us updated. Would love to see how you finish it up. Nice work.
Squint77 is offline   Reply With Quote
Old 09-18-2009, 10:42 PM   #10
Border Dave
How do you keep dust from getting sucked through the cotton gauze air filter element?
Border Dave is online now   Reply With Quote
Old 09-19-2009, 09:09 AM   #11
nriver
2011 JK Wrangler
nice..........
Why do I post here?
nriver is offline   Reply With Quote
Old 09-19-2009, 09:21 AM   #12
Unlimited04
Unlimited04's Avatar
added to the CAI FAQ.
Unlimited04 is offline   Reply With Quote
Old 09-19-2009, 11:04 AM   #13
imjbinkc
I think you're asking for trouble with this setup. You need to go ahead and finish the conversion to a hummer type intake soon as this looks like it would get soaked the first time it rains/snows...
imjbinkc is offline   Reply With Quote
Old 09-19-2009, 03:11 PM   #14
dking051
like i said this is just a temp job for now till i do the full hummer style intake...and really removing the cowl is not a big deal at all...how often do you check/change ur fitler anyway...? its not a strick trail rig...its my DD so its not bein exposed to an over amount of dirt/mud/water, etc.
Old 09-19-2009, 03:12 PM   #15
dking051
im going to get a reverse hood scoop for the cowl for now to prevent water from comin in...yet still get good airflow off the windshield...and i may put a lil piece of sheet metal arced around the intake to prevent direct contact w/ water...& im going to get a prefilter for it as well...
Glock Forum
