Coil Spring Compressor ? - Page 2 - JeepForum.com
post #16 of 25 Old 07-08-2010, 10:32 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you have a pry bar?
If so, use the pry bar to slightly compress the spring and also as a ramp to guide the spring in to place.
Once you get it lined up, give the spring a kick and it will pop right in.
Wheelin98TJ is offline
post #17 of 25 Old 07-08-2010, 11:52 PM
Guardian7
You buy a set for $10 at harbor freight to get the job done. Without the spring compressor you will need to disconnect the track bar, shocks, and maybe the lower control arms, once the coils are in use a floor jack to raise the axle enough to line up the lower control arms so they bolt up.
I LIVE I RIDE I AM
Guardian7 is offline
post #18 of 25 Old 07-09-2010, 12:17 AM
Fropleyqk
Fropleyqk's Avatar
I was able to get all my springs on except the rear drivers side. Went to advanced auto and they rent it to you for free. It was a $50 deposit that was 100% refunded when you return the compressor. Make sure you get an external comressor tool, not one designed for struts. And BE CAREFUL!!! If you compress one and it lets go, its going to do some damage.
Fropleyqk is offline
post #19 of 25 Old 07-09-2010, 06:39 AM
domano 68
good stuff
2005 Wrangler Unlimited
domano 68 is offline
post #20 of 25 Old 07-09-2010, 08:41 AM
RubiconRazorbac
RubiconRazorbac's Avatar
Originally Posted by lupinsea View Post
I've tried installing even 2" lift springs without spring compressors and I can't manage it on my rig, even though I hear a lot of first hand accounts from people on JF being able to do so w/ 2-4" lift springs.
I don't get what I'm doing wrong but I simply can't get it to work.
So when ever I've needed to do spring work I just borrow the spring compressors. Rather than fighting the spring the whole process just goes much smoother with the compressors. And yes, if you want / need to use them you'll need the ones that fit on the outside of the spring. Even then, pay attention to their orientation around the spring. As you tighten or loosen the compresson bolts they can end up getting "stuck" in the bracketry of the axles / frame. It's not a big deal, just pay attention to how the clamps are oriented.
^This. All of it. I know there are folks that don't need them and hey, I wish I was one of those folks
You may not need them, but you'll darn sure want them
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #21 of 25 Old 07-09-2010, 11:41 AM Thread Starter
242TJ
Headed over to the garage to work on it. We'll see how it goes. I will post what I tried and what worked for me tonight. Thanks for all the suggestions.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #22 of 25 Old 07-09-2010, 10:54 PM Thread Starter
242TJ
Got the front springs in and the arms bolted on with the help of...
Tilting one end of the axle up
Taking off the frame bolts for the LCAs
Using a hand winch hooked up to a furnace bollard to get the arms in
I feel like two hands isn't enough to get some of this done, but I did. Another 5 hour session in the garage, but at least I have something to show for it this time. The couple of Jeeps I have helped lift never had this much trouble. Not sure what my problem is but this one is really fighting me...
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #23 of 25 Old 07-10-2010, 07:20 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
if i was closer id help.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #24 of 25 Old 07-10-2010, 07:28 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you forgot bumpstop extensions. now you gotta do it all over again. if you pull the jounce bumper (rubber thing) out and pull the bumpstop cup off, it makes things a lot easier
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #25 of 25 Old 07-10-2010, 11:29 AM Thread Starter
242TJ
These springs are really stiff and I am running 33s on a 4.5" lift, so I don't think the bumpstops will be an issue, but I could be in for a nasty surprise.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
coil , spring , compressor
spring compressor help monjorrow TJ Wrangler Technical Forum 10 12-19-2009 09:40 AM
Installing spacers with out a coil spring compressor? Alexia TJ Wrangler Technical Forum 19 04-07-2009 08:29 PM
Help with Coil Spring Compressor jmelgin JK Wrangler Technical Forum 12 07-06-2008 07:38 PM
Spring Compressor? defleppardsg TJ Wrangler Technical Forum 7 06-20-2008 12:08 PM
Wratchet Strap Coil Spring compressor! BDuece TJ Wrangler Technical Forum 2 02-26-2007 02:15 PM
