Coil Spring Compressor ? - JeepForum.com
post #1 of 25 Old 07-08-2010, 03:00 PM Thread Starter
242TJ
I am in the middle of my lift and can't get my new 4" springs in. I have taken everything off, but installed the new control arms because I couldn't get them in when the new springs were on. Now that the arms are in the axle wont drop enough to get the spring in.
Does anyone have experience with coil spring compressors? I assume you need a two piece setup that hooks onto the outside of the springs. My new springs have a spring rate of about 220 inch lbs. How much can these spring compressors handle?
Thanks in advance for your help.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #2 of 25 Old 07-08-2010, 03:14 PM
jdub36
you can rent them from most chain auto parts stores. You will need the ones that are used on Struts since they mount to the spring from the outside. Before you go through the trouble of a spring compressor you might try un bolting the control arm from the frame instead of the axle. I was having the same issue you are and when i did that i was able to make it work. After you get the spring in you can hook a ratchet strap to the axle and pull it back until the control arm lines back up. Hope this helps.
jw
jdub36 is offline
post #3 of 25 Old 07-08-2010, 03:16 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
i bought my strut compressors from pep boys for around $35. well worth it and makes life easy. i have already used them 3 times in less than 2 months.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #4 of 25 Old 07-08-2010, 03:37 PM Thread Starter
242TJ
Originally Posted by jdub36 View Post
jdub36
I tried the ratchet strap when I was trying to get the axle end bolted up. I will try it the other way tomorrow.
$35 is not that bad if that's what I need.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #5 of 25 Old 07-08-2010, 03:59 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you have the shocks and the sway bar links disconnected at the axle when you are trying to install the springs?
Are you pushing down on the axle?
Are you using a pry bar to help slide the spring in?
If you absolutely have to, you can unbolt one end of the track bar and you'll pick up a ton of axle droop then.
I have a set of coil spring compressors/strut spring compressors and I never use them on my TJ or anyone else's.
Wheelin98TJ is offline
post #6 of 25 Old 07-08-2010, 04:33 PM
Cavitation
Remove TB,
Remove lower end of shocks.
Unbolt the sway links.
Jack up one side push down on the opposite.
I had to use compressors on the front of my jeep but he rears popped right in.
Cavitation is offline
post #7 of 25 Old 07-08-2010, 04:35 PM
Apex
Recon death squad
Apex's Avatar
I didn't need compressors for my RE 4.5" springs when I first did my lift.
Like stated above, raise the opposite side and push down on the side you are trying to get the spring into.
Make sure your shocks and sway bar links are disconnected.
Apex is offline
post #8 of 25 Old 07-08-2010, 05:10 PM
lupinsea
lupinsea's Avatar
I've tried installing even 2" lift springs without spring compressors and I can't manage it on my rig, even though I hear a lot of first hand accounts from people on JF being able to do so w/ 2-4" lift springs.
I don't get what I'm doing wrong but I simply can't get it to work.
So when ever I've needed to do spring work I just borrow the spring compressors. Rather than fighting the spring the whole process just goes much smoother with the compressors. And yes, if you want / need to use them you'll need the ones that fit on the outside of the spring. Even then, pay attention to their orientation around the spring. As you tighten or loosen the compresson bolts they can end up getting "stuck" in the bracketry of the axles / frame. It's not a big deal, just pay attention to how the clamps are oriented.
- Jay
lupinsea is offline
post #9 of 25 Old 07-08-2010, 06:52 PM
Mike_Motorbike
How about $10 . This is the one I use.....it is tough to get it in the tight area though.
MacPherson Strut Spring Compressor Set
this would be Ideal
Single Action Strut Spring Compressor
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #10 of 25 Old 07-08-2010, 07:13 PM
J03_TJ
this would be Ideal
I have used that cheaper one several times. ruined the first set, then made sure and put grease on the threads for the second set and they have been going good for two spring changes.
J03_TJ is offline
post #11 of 25 Old 07-08-2010, 07:16 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i rented a set of spring compressors from Checker the first time, but the second time i pulled the springs i just bought them. i got tired of using gas to go rent them
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 25 Old 07-08-2010, 07:41 PM Thread Starter
242TJ
Thanks for all the replies, I appreciate it. As of now, the only thing connected to the axle are the 4 control arms, front driveshaft and a breather hose. No brakes, TB, shocks, drag link, ect.
I will try the pushing one end up really far and if that wont work, I can try and unbolt the frame end of the LCAs. I have already spent 5 hours taking my arms on and off so I would be more than happy to go rent a spring compressor if it comes to that. Sounds like they normally are not needed but they make things much easier.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #13 of 25 Old 07-08-2010, 07:54 PM
Neil F.
They DO make easier. I used Autozone loaners twice. With an electric impact I could zip the spring down in a couple minutes and pop it right in. IMHO, you wasted too much time already.
Neil F. is offline
post #14 of 25 Old 07-08-2010, 08:30 PM
Cavitation
Oh yeah remove the breather also
post #15 of 25 Old 07-08-2010, 09:54 PM Thread Starter
242TJ
I will see if I can get my hands on my friends air compressor and impact. I really did waste my time on this. I feel like an idiot looking at the front end for hours and not coming up with new options, which is why I love hitting up the forum.
Thanks for the help guys.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
coil , spring , compressor
spring compressor help monjorrow TJ Wrangler Technical Forum 10 12-19-2009 09:40 AM
Installing spacers with out a coil spring compressor? Alexia TJ Wrangler Technical Forum 19 04-07-2009 08:29 PM
Help with Coil Spring Compressor jmelgin JK Wrangler Technical Forum 12 07-06-2008 07:38 PM
Spring Compressor? defleppardsg TJ Wrangler Technical Forum 7 06-20-2008 12:08 PM
Wratchet Strap Coil Spring compressor! BDuece TJ Wrangler Technical Forum 2 02-26-2007 02:15 PM
