coil spacer lift question - JeepForum.com
post #1 of 7 Old 03-28-2011, 03:02 PM Thread Starter
MikeyMercier
gonna put 2" spacers on the jeep soon already got 3" coil lift, the question is when i add the spacers for a total of 5" over stock ride height what problems do you think i might run into or should it just be smooth sailing (for a jeep ) and do you think i should replace the shocks if so anyone wanna send me in the right direction?
MikeyMercier is offline
post #2 of 7 Old 03-28-2011, 03:06 PM
LilyBayXJ
Spacers will be fine. You need longer shocks. May need a SYE if you don't already have one. Try using the search function before starting a thread covering information already out there. Check this out:
http://www.jeepforum.com/forum/f9/tj...embers-722109/
^ That should be all you need. Have a nice day.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #3 of 7 Old 03-28-2011, 03:08 PM
jabroni3411
need more info mostly but from ur profile you may run into driveline vibes. a SYE kit might be needed. depends what shocks you have now. bumpstops extended. shocks everyone will refer you to OME or billstein
Check My Build
jabroni3411 is offline
post #4 of 7 Old 03-28-2011, 03:09 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
don't add 2" spacers on top of 3" lift springs. horrible idea.
search about something called coil bind. you'd have to bumpstop most of the uptravel out of your suspension to prevent issues.
if you want 5" of lift, buy a 5" lift with 5" lift springs.
See all that crap linked below, in my sig? Read that.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 7 Old 03-28-2011, 03:11 PM
mdm
Farm Wheeler
You are going to have a 5" lift. You'll need most or all of the following:
Adjustable control arms, front & rear.
Shocks, front & rear.
Slip yoke eliminator & CV drive shaft.
Control arms, upper & lower, front & rear.
Longer anti-sway bar links, front & rear.
Longer bump stops, front & rear.
You'll be better off buying new, longer springs.
You can't just throw the spacers on top of the coils and drive away.
Do some research on what the better lift kits include that give you 5-6 inches of lift. That's what you'll need at a minimum.
Welcome to the forum.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 7 Old 03-28-2011, 03:11 PM
jabroni3411
x2
Check My Build
post #7 of 7 Old 03-28-2011, 03:14 PM Thread Starter
MikeyMercier
thanks guys and sorry for not searching
coil , lift , shocks , spacers , tj
Coil spacer with rough country 2.5 lift question jrwhite07 TJ Wrangler Technical Forum 17 06-04-2009 05:54 PM
lift + coil spacer question.. BiGEN JK Wrangler Technical Forum 3 06-01-2008 10:20 PM
coil spacer lift hotnutz TJ Wrangler Technical Forum 20 03-11-2008 09:11 AM
coil spacer lift chadwickinator TJ Wrangler Technical Forum 3 04-03-2006 11:48 PM
Need help with coil spacer lift jimj911 TJ Wrangler Technical Forum 1 03-06-2006 06:09 PM
