coil over or long arm - JeepForum.com
post #1 of 12 Old 10-10-2010, 02:04 AM Thread Starter
amanscorned
I have a four inch sky jacker installed now I want to run 35's and have alot more articulation what are the pos and cons of a coil over lift, wich would you suggest a 6" long arm kit or a coil over and why. I already have installed adjusted upper control arms front and rear and SYE kit with CV drive shaft plan on the 4wd shifter relocation bracket or correction kit any advice would be highly appreciated thanks guys
amanscorned is offline
post #2 of 12 Old 10-10-2010, 02:12 AM
JeepO7
Long arm.
JeepO7 is offline
post #3 of 12 Old 10-10-2010, 02:28 AM
ArrizX
Are you saying you would consider running coil overs with out a long arm setup?
ArrizX is offline
post #4 of 12 Old 10-10-2010, 06:36 AM
squigy123
You should run long arms when running coil overs. So i think your best bet would be get long arm suspension first then when your ready swap to coilovers.
squigy123 is offline
post #5 of 12 Old 10-10-2010, 07:06 AM
never monday
sure, why not
never monday is offline
post #6 of 12 Old 12-07-2010, 03:42 PM Thread Starter
amanscorned
I got ya, so the coil overs are more like an upgrade for an existing long arm suspension lift? What are the advantages of coil over springs as to a long arm suspension with the supplied coil springs
post #7 of 12 Old 12-07-2010, 03:48 PM
RockMonster
just curious..are you going to be installing these coilovers yourself?? because your going to need to do a ton of research check out the coilover bible or whatever it is on pirate. it will shed tons of light on your questions.
here is the link: http://www.pirate4x4.com/tech/billav...lovers/Part_1/
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #8 of 12 Old 12-07-2010, 03:54 PM
DstroyrOfWrldz
I don't think the coil over would gain you much with short arms, definitely long arms first.
Joe
1999 Wrangler Sahara
2005 Wrangler Unlimited (Sold 9/2012)
DstroyrOfWrldz is offline
post #9 of 12 Old 12-07-2010, 04:05 PM Thread Starter
amanscorned
thanks guys for your input I really appreciate it
post #10 of 12 Old 12-07-2010, 06:03 PM
pcoplin
pcoplin's Avatar
Why do you want coilovers?
pcoplin is offline
post #11 of 12 Old 12-07-2010, 08:42 PM
Apex
Recon death squad
Apex's Avatar
seems like a lot of internet babble here.
The good advice that was given was to read the Pirate4x4 coilover link provided. There is a lot to be learned...it isn't just "Eh, I want coilovers"
Apex is offline
post #12 of 12 Old 12-26-2010, 01:05 AM Thread Starter
amanscorned
Well I researched the pirate 4x4 website, and i have to say I am highly impressed I found all the info I needed and realize the long arm six inch kit is all i will need thanks for the insight guys
2" inch coil lift with long arms?!?! DINOCAVE TJ Wrangler Technical Forum 10 08-29-2009 06:13 PM
SE coil vs Rubi coil for sagging rear NYTJ TJ Wrangler Technical Forum 6 04-15-2008 07:52 AM
How long does ignition coil assembly last? hunter44102 TJ Wrangler Technical Forum 2 03-10-2008 08:43 AM
6" Long arm w/ 2.5" Coil-overs ChadCielencki TJ Wrangler Technical Forum 11 12-22-2006 07:13 AM
Coil springs or coil spacers? SecondTJ TJ Wrangler Technical Forum 34 10-18-2006 03:33 AM
