Coil install question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Coil install question
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread Today, 12:03 AM   #1
Mowgli25
I'm installing some new 2.5 coils and was wondering if it's okay to use the jack to push the opposite side of the axle all the way up to get it to drop all the way down on the opposite side?
Mowgli25 is online now   Reply With Quote
Unread Today, 05:56 AM   #2
2jhanna
I think this is common practice, but hopefully others will chime in.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Unread Today, 05:59 AM   #3
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if the spring is removed on the side you are jacking off of, yes it's common practice. In fact, it's common practice to cycle the axle to full bump, full droop and full flex on both sides to check suspension clearances while the springs are completely removed.
here's how it's done: http://www.jeepforum.com/forum/f96/j...arned-1513528/
Unlimited04 is offline   Reply With Quote
