Quantcast Codes p0301 p0304 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Codes p0301 p0304
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 07-07-2009, 09:39 AM   #1
ProjectWhiteTJ
Codes p0301 p0304
Hello guys I have searched this topic to death. My jeep will pull these codes when it's cold. Once up to operating temps if I clear the codes they will not come back. The jeep seems to run at full power but every now and then will hiccup and backfire. Also it seems to shake alot at idle although it holds the rpms at ~700. The jeep has new plugs, wires, cap, rotor. Any help would be greatly appreciated.
ProjectWhiteTJ is offline   Reply With Quote
Old 07-07-2009, 09:58 AM   #2
jeepmojo01
jeepmojo01's Avatar
If you google jeep diagnostic trouble codes it will tell you that your computer has detected a misfire in cylinder #1 and cylinder #4
jeepmojo01 is offline   Reply With Quote
Old 07-07-2009, 10:08 AM   #3
ProjectWhiteTJ
Sorry I forgot to mention that I know what the codes are, i'm just trying to figure out what's causing it.
Old 07-07-2009, 11:38 AM   #4
Vigher
Vigher's Avatar
I'm gonna take a guess that you used the Double Platinum plugs, if not disregard what I'm about to say.
Remove the Platinum plugs and install standard champion or autolite plugs, your jeep will never be happier!
Vigher is offline   Reply With Quote
Old 07-07-2009, 11:49 AM   #5
ProjectWhiteTJ
I wish that was the reason. I used standard copper champions
Old 07-07-2009, 12:19 PM   #6
acrijos
acrijos's Avatar
Check the spark-plug wires, they might be loose or not making good contact.
We don't stop playing because we grow old. We grow old because we stop playing.
acrijos is offline   Reply With Quote
Old 07-07-2009, 12:32 PM   #7
ProjectWhiteTJ
I've checked to make sure they are "clipped" onto the cap and plugs. Next thing I'm gonna do is check the wires out for continuity. Also I swaps the 1 and 4 cylinder plugs with 2 and 3 and it still coming up with p0301 and p0304. The #1 cylinder plug was black. But 4 was clean. I'm so lost!
Old 07-07-2009, 12:50 PM   #8
Border Dave
Did you check the gap of your plugs?
Border Dave is online now   Reply With Quote
Old 07-07-2009, 01:03 PM   #9
ProjectWhiteTJ
No I haven't. They are all gapped how I bought them. I doubt it's the gap because when I swapped plugs it should have misfired on 2 and 3 then.
Old 07-07-2009, 01:38 PM   #10
Border Dave
That's good logic, but I would check the gap nonetheless. Oftentimes, they come gapped entirely wrong. Happened to me many times.
How old are your wires? edit: I see that you said they're new. Try switching the wires around and see what happens.
Old 07-07-2009, 07:50 PM   #11
ProjectWhiteTJ
ya the wire switching and i will check the gap. what is the gap "supposed to be"
thanks for the help for far. with all this rain its tough to get it on the road and drive it.
Old 07-07-2009, 09:11 PM   #12
Vigher
Vigher's Avatar
spark plug gap should be 0.035
Old 07-08-2009, 07:07 AM   #13
ProjectWhiteTJ
Thank you for the info. Hopefully I get some time today to work on it.
Old 07-09-2009, 08:11 PM   #14
ProjectWhiteTJ
ok guys plugs were all within .002 of each other from .035. swapped the plug wires on 1 and 4 to diffrent plugs and 1 and 4 still missfired. i am completely LOST
Old 07-09-2009, 08:20 PM   #15
jeeptj19992001
did you change out your distributor cap and rotor?
did you check the compression of those two?
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline   Reply With Quote
Glock Forum
