code po157 - JeepForum.com
post #1 of 4 Old 05-06-2010, 10:52 PM Thread Starter
bigwyrm
code po157
I ran a code reader and it came up with po157, any ideas what it is?
bigwyrm is offline
post #2 of 4 Old 05-06-2010, 10:54 PM
USAFRecon
Try the search for now on
O2 sensor input voltage below normal operating range.
Lower bank 02 sensor needs replaced
http://www.jeepforum.com/forum/f9/tj-forum-faq-615132/
http://www.jeepforum.com/forum/f9/fa...-codes-778086/
USAFRecon is offline
post #3 of 4 Old 05-06-2010, 10:55 PM
Buffalo99
P0157 (M) 2/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range. I'm pretty sure that's indicating an error for the downstream sensor on bank 2 (cylinders 4-6). But, before you take my word for it... I'd double check just to make sure.
Hope that helps.
Buffalo99 is offline
post #4 of 4 Old 05-07-2010, 10:59 PM Thread Starter
bigwyrm
thanks guys!
I appreciate it!
bigwyrm is offline
Misfire code P0301 & Fuel level code P0463 related? -OlllllO- TJ Wrangler Technical Forum 6 04-28-2010 02:55 PM
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 08:46 AM
Engine Code P 304, Engine code P0304 JeepinRRT TJ Wrangler Technical Forum 4 09-23-2009 09:26 AM
YJ EVAP solenoid code/AC Code, Stalling/Dying when coming to a stop issues fyallm YJ Wrangler Technical Forum 16 07-13-2009 07:33 AM
sorry for being the 900th trouble code post but i couldnt find what code 24 was shurd25 YJ Wrangler Technical Forum 3 03-24-2007 08:25 AM
