Code P1391 - JeepForum.com
post #1 of 11 Old 08-05-2010, 09:57 AM Thread Starter
barcand
Code P1391
My 97 Wrangler Sport has a check engine code of P1391. I have replaced the Crankshaft positioning sensor and that did NOT correct the issue. I am at a loss of what to do next. When google p1391, it seems that this code is always tough to troubleshoot. Your ideas and thoughts are much appreciated.
1997 Jeep Wrangler Sport
4.0 Straight 6
5 Speed Manual
205 k
Thanks
Brian
barcand is offline
post #2 of 11 Old 08-05-2010, 10:20 AM
oakmckinley
In my manual it says "Intermittent loss of either Camshaft or Crankshaft position sensor".
Just so you know I replaced a Crank position sensor once and the sensor itself was defective, I guess they have a history of being crappy.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #3 of 11 Old 08-05-2010, 10:23 AM
Sundowner
That code is listed as "intermittent loss" of either the Crankshaft Positioning Sensor, or the Camshaft Positioning Sensor. Keywords: intermittent and loss. So, at times, it's working...
Thus, your first check should be wiring and connections.
In fact, that's your first step every time...wires, connectors, fuses, relays, etc. Simple stuff first. By not doing so, you've replaced a working, functional sensor. (Not that I'm getting on your case...that was more for people reading this in the future.)
So, check that stuff first, and then check the cam sensor. They can both trip that code.
Sundowner is offline
post #4 of 11 Old 08-10-2010, 07:39 AM Thread Starter
barcand
I am on my 2nd crank sensor and the light is still on p1391
I checked all of the connections and they seem fine. Is it worth trying the camshaft postioning sensor?
barcand is offline
post #5 of 11 Old 08-10-2010, 07:45 AM Thread Starter
barcand
I just noticed that my Jeep 97 sport 6 cyl doesnt have a camshaft positioning sensor..
barcand is offline
post #6 of 11 Old 08-10-2010, 07:47 AM Thread Starter
barcand
When advanced autoparts put it on their scanner, it came up with p1391 then when he scrolled through it stated a misfire on all six cylinders. It was already tune-up about 20k ago.
barcand is offline
post #7 of 11 Old 08-10-2010, 06:20 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did you look in the distributor?...
Knuckelhead is offline
post #8 of 11 Old 08-11-2010, 07:15 AM Thread Starter
barcand
What should I look for?
barcand is offline
post #9 of 11 Old 08-11-2010, 07:56 AM
ManInBlackTJ
my brother has a 96 xj that had pretty much the same problem. I took his distributor cap off and found the bushings were shot in the distributor, I could grab the rotor and move it about half an inch side to side (over 190kon the engine). We replaced the dizzy and no more problems!
ManInBlackTJ is offline
post #10 of 11 Old 08-11-2010, 07:58 AM Thread Starter
barcand
Ok, because I am not experiancing any misfires, it is just what the code is throwing...
barcand is offline
post #11 of 11 Old 08-19-2010, 10:37 AM Thread Starter
barcand
I have resolved this by putting in a new distributor... thanks to all..
barcand is offline
p1391 , code , tj , wrangler
Jeep finely set a code (P1391) but NO demarkos TJ Wrangler Technical Forum 1 02-09-2014 10:05 PM
Engine code P1391 shawnsix66 TJ Wrangler Technical Forum 3 08-06-2013 08:26 PM
Code P1391 but jeep runs fine, can't pass inspection 93CBRA TJ Wrangler Technical Forum 3 09-09-2012 03:50 PM
P1391 Code Sartep TJ Wrangler Technical Forum 4 05-29-2007 05:32 PM
