Code P0463 What is it? - JeepForum.com
post #1 of 16 Old 11-13-2009, 07:59 PM Thread Starter
popeyesides
popeyesides's Avatar
Turned on Jeep and check engine light came on and fuel gauge went from full to empty. Turned off/on two more times and same thing happened. Just checked code and it came up as P0463. Does anyone know what this code is?
popeyesides is offline
post #2 of 16 Old 11-13-2009, 09:17 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
P0463 Fuel Level Sending Unit Volts Too
High
Fuel level sensor input above acceptable voltage.
GOLENJEEPTJ is offline
post #3 of 16 Old 11-13-2009, 10:04 PM Thread Starter
popeyesides
High
What does this mean, Is it something to fix myself?
post #4 of 16 Old 11-13-2009, 10:12 PM
fishinjeeper
might just try replacing the sensor incase it has gone bad
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #5 of 16 Old 11-13-2009, 10:24 PM
WILLY348
I am also haveing this same code.. i've had it for probably 5-6 months now. None have given me a real good response on what causes it.. and i dont want to go to the stealership and pay them $700 for a $50 job.
Mine is very odd. The light only will come on if i let my jeep idle for a certain amount of time after i have filled my jeeps tank. After i burn off a few gallons, the light goes away. That is until i fill up again. But, like i said, if i don't let it sit there and idle (like let it warm up in the mornings) it will not come on.
Other then that.. my jeep drives perfectly.. so i havent really thought much of it. I did at first.. but now its been like 6 months and its still driving perfectly
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra
WILLY348 is offline
post #6 of 16 Old 11-14-2009, 05:12 AM
nmj48
I have the same issue with my 05 rubicon- fill the tank drive about 100km(60m) CEL comes on fuel gauge goes to empty, next time i start it up fuel gauge works buy the third time it's started the CEL is out. This started about 6 months ago.actually posted on here when it first happened. i just reset the CEL with my code reader each time it happens.
I have looked into this and because it always happens at the same time, I believe it is the sending unit in the fuel tank that is the problem,and not a loose connection or broken wire. The sending unit consist's of a float and a resistor track card (it is attached to the fuel pump module)to tell you how much fuel you have.
I believe there is a bad spot on the resistor track card and when the fuel tank is near full it is causing the voltage to be too high(PO463)
The voltage has to be over 4.9v for 90 seconds or more to trigger the code.
The 05 fsm states that to replace the sending unit you have to replace the fuel pump module,but you can buy a sending unit and not the pump module from the dealer which leads me to believe that the sending unit can be replaced on it's own, either way you have to drop the fuel tank.
In Canada the sending unit is $110 p/n 05161336AA and the fuel pump module (includes sending unit) is $330 p/n 05161335AB, i would imagine these prices are about half in the U.S. I have not replaced either yet.
nmj48 is offline
post #7 of 16 Old 11-14-2009, 06:05 AM
ProjectWhiteTJ
I had the same code it was the fuel sending unit. A 3t
ProjectWhiteTJ is offline
post #8 of 16 Old 11-14-2009, 06:39 AM
jaymann
Mine has done this twice, only when i fill the fuel tank all the way. I havent noticed any difference in how it runs and the check engine light just goes off by itself.
jaymann is offline
post #9 of 16 Old 11-14-2009, 08:49 PM Thread Starter
popeyesides
Thanks guys for the responce, It now makes sense, I will check it all.
post #10 of 16 Old 02-13-2010, 11:22 AM
jeep2k9
so did it end up being the fuel sending unit?
jeep2k9 is offline
post #11 of 16 Old 02-18-2010, 08:05 AM
Raoul
I've got the same problem... but only when Ifill my tank with Ethanol E85.
2005 Extreme sport TJ, Teraflex Sway Bar System, 32 BFG, 2" lift, Full powertraxed, Warn M8000.
Raoul is offline
post #12 of 16 Old 05-05-2010, 06:40 PM
Jayson
2005 KJ Liberty
Question NC
Is there anyone that has seen engine damage by letting this go?
Jayson is offline
post #13 of 16 Old 05-05-2010, 08:18 PM Thread Starter
popeyesides
I never did change anything and it has only happened one more time since 11.14.09 when I fill the tank all the way and mine has been running fine, and I now have 14,000 miles on it.
post #14 of 16 Old 10-20-2011, 10:21 PM
RDaniel2405
RDaniel2405's Avatar
just found this thread. I know its old, but this happen to my tj today, again. I just went home and cleared the code. This is the 3rd time my jeep has done this in 2 years.
MY DAILY DRIVER BUILD
WTB Impact Orange half doors.
RDaniel2405 is offline
post #15 of 16 Old 06-20-2015, 11:29 AM
pblanton
1973 CJ5
I know this is an old thread but still relevant, and I have an answer, so I'm sharing for the benefit of the next Googler who has the P0463 code on their Jeep...
Mine is an '05 KJ Liberty and this started about eight months ago. It would work fine until the gauge read about half-full, then the dash would go "BING", the check engine light would come on and the fuel gauge would drop to "E". It does it everytime we drive it. When you start it, the gauge reads correctly, but sometime during your trip, it'll "BING" and drop to "E".
I bought an OBD II reader yesterday (been wanting one for a while and this justified it to the wife), and read the code as...
P0463
Fuel Level Sensor A Circuit
High
The OBDII reader says "$10 Generic" at the top of the screen. Don't know what that means.
It's now doing it around 3/4 tank of fuel, but today when I went to read the code, the gauge didn't register at all, so I think my sending unit is now completely bad.
For what it's worth, I started a new thread here...
http://www.jeepforum.com/forum/f28/2...ng-up-3260193/
before I read the code, which allowed me to find this thread.
pblanton is offline
Code p0700 and p0463, What is it. popeyesides TJ Wrangler Technical Forum 3 06-20-2015 12:04 PM
Misfire code P0301 & Fuel level code P0463 related? -OlllllO- TJ Wrangler Technical Forum 6 04-28-2010 02:55 PM
Engine code P0463 still happening WILLY348 TJ Wrangler Technical Forum 0 07-11-2009 02:43 PM
scan code p0463 mJUSTINm TJ Wrangler Technical Forum 5 03-01-2009 08:06 PM
P0463 Error Code - Sending unit bad? mrrrl TJ Wrangler Technical Forum 1 04-02-2007 02:08 PM
