Code P0420 and Rattling Underneath - JeepForum.com
post #1 of 12 Old 09-01-2009, 10:13 AM Thread Starter
valacech
valacech's Avatar
wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
You are not a unique snowflake.
valacech is offline
post #2 of 12 Old 09-01-2009, 11:09 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
If the main Cat is rattling,just replace it with the Magnaflow.The $100 replacements are for the 97-99 models.On my old Jeep,it was welded on and I cut it off.The Magnaflow has nice wide clamps that work very well.
TheBoogieman is offline
post #3 of 12 Old 09-01-2009, 01:17 PM
mouse
mouse is offline
post #4 of 12 Old 09-01-2009, 03:53 PM Thread Starter
valacech
valacech's Avatar
Boogie: So I can basically just cut that sucker out of there (measuring correctly of course) and the hardware that comes with their system will enable me to clamp it in place with no leaks? Sounds too good to be true...
valacech is offline
post #5 of 12 Old 09-01-2009, 04:47 PM
tooofast
I think its this one you need right?
Magnaflow 23227 - MAGNAFLOW Performance Direct Fit Catalytic Converter for 97-99 Jeep® Wrangler TJ with 4.0L Engine - Quadratec
Dave
4" clayton long Arm, 5 inch rear stretch. CRAWLER tank. 35" KM2 muds, 1" MML from Brown Dog. Rear D44 Locked with a Detroit & trussed on Alloy Shafts, 4 point triangulation. Rear disc conversion. AtoZ Cage. Rubicon OR241 4:1. Front D30, Polly Performance Sleeve kit, locked with ARB, Alloy Shafts and HD steering linkages. Clayton belly up and oil pan skids, PSC Rocker Knockers, ORO air powerd Swayloc, Onbard Vita 450 and tank for fills and ARB compressor for the locker. Covered in dents.
tooofast is offline
post #6 of 12 Old 09-01-2009, 07:27 PM Thread Starter
valacech
valacech's Avatar
I've got a 2004 though. This is such a pain in the neck. It's got the two mini catalysts and then the down pipe. Do I even need those things?
valacech is offline
post #7 of 12 Old 09-01-2009, 08:25 PM
cj847
The first thing I advise on this kind of situation is DO NOT just randomly throw money at it. I would never repair a P420 or P430 without turning the CEL off several times and making sure I got the code to come back again consistently. Anything you do to try to fix this issue will be very expensive and it could seriously just be a bad tank of gas. Also, be sure that it is not still covered under your warranty. Some emmission items are covered for 100k or more miles.
First your trouble code:
OBD-II Trouble Code: P0420 Catalyst System Efficiency Below Threshold (Bank 1)
If you're gettting a P420 that tells you one thing; if you're getting a p430 that's telling you something else; if you get them both at the same time that gives you other hints.
My daughter recently had a P420 and P430 on her Nissan. After turning it off 3 times it has been trouble free for over 6 months and I never replaced anything. Good luck!
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #8 of 12 Old 09-01-2009, 08:40 PM Thread Starter
valacech
valacech's Avatar
Thanks for the advice. The only thing is the rattling underneath the car. Those two together have pretty much convinced me that its the cat. Thoughts?
valacech is offline
post #9 of 12 Old 10-14-2009, 08:06 AM
jacobfudgepops
mine rattles like crazy, i need to either replace it, or just cut it off, anybody ever cut there cat off and just straight piped it with a flowmaster 40??
5"superlift,1"body 35s. still building
jacobfudgepops is offline
post #10 of 12 Old 10-14-2009, 08:51 AM
LDO
Check with the dealer before spending the money!! Mine rattles too and I''m getting it replaced under the emission warranty. 2004 with 36K miles. They need the VIN and miles to check and it only takes a minute to see if it is under the emission warranty.
LDO is offline
post #11 of 12 Old 01-01-2011, 12:29 PM
mirra9112
I drive a 99 Wrangler with an aftermarket exhaust manifold, a Magnaflow direct fit catalytic converter, and a Banks Monster cat back. The exhaust system has been installed since July without a problem.
Two weeks ago I found a P0420 code. My friend reset it and it stayed off for a week or so until it came back on.
There is also a loud rattle that is coming from under the Jeep. I really don't want to replace the catalytic converter when this one is just five months old. Any ideas of where to begin?
mirra9112 is offline
post #12 of 12 Old 02-17-2011, 01:02 PM
TBoons
TBoons's Avatar
My 04 with 50k on it is throwing the cat. CEL and I have been denied warranty work due to abuse. Bone stock TJ. They state it's been up to the windshield in water. I even have a case open with corp. they are no help.
Gotta pick up the Jeep todray from them.
04 TJ RME
MODs: Sirius Radio, Oil Changed (x2), Tires Rotated (x1)
TBoons is offline
It's back!!! code p0420 convertor low eff. vosevichs TJ Wrangler Technical Forum 1 11-05-2010 09:51 AM
OBD Code P0420(M) - possible causes? Kiwi Jeeper TJ Wrangler Technical Forum 8 03-07-2009 01:51 AM
Check Engine Code p0420 gtospeeding TJ Wrangler Technical Forum 12 05-08-2007 11:43 PM
Rattling from underneath Moxzart TJ Wrangler Technical Forum 0 10-27-2006 08:34 AM
rattling underneath johnWJ TJ Wrangler Technical Forum 8 11-16-2005 01:35 PM
