code help p0499 u0155 - JeepForum.com
post #1 of 10 Old 02-17-2009, 06:02 PM Thread Starter
Bmel17
just popped these over the weekend, wondering if anyone knows what they are so I can fix'em.
The jeep starts up fine, but the electrical seems to restart, ie. "beep" radio stops and restarts. Also the gauges go dead then seem to reboot.
P0499-NVLD Canister Vent Valve Solenoid Circuit High
----A shorted high condition detected in NVLD solenoid circuit.
What is that?
u0155-Lost Communication With Instrument Panel Cluster (IPC) Control Module
Any help is appreciated
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #2 of 10 Old 02-18-2009, 03:37 PM Thread Starter
Bmel17
no one ????
08 HD Nightster
Bmel17 is offline
post #3 of 10 Old 02-18-2009, 03:50 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Couldn't even find those codes on my 02 FSM? Just going to have to wait on someone to chime in! Do you have an 06 FSM?Sounds like an PCM but don't quote that!
GOLENJEEPTJ is offline
post #4 of 10 Old 02-18-2009, 04:25 PM Thread Starter
Bmel17
nope, yeah i'm not sure what they heck these codes are! I think I have a few weeks left on my warranty, but I'm sure the stealership is not gonna honor it b/c of the alarm I had installed.
08 HD Nightster
Bmel17 is offline
post #5 of 10 Old 02-18-2009, 04:41 PM
N5RMQ
Unless your alarm is the cause of the problem they have to cover the repair under warranty. If the alarm or its wireing is the cause......forget it.
"No man who refuses to bear arms in defense of his nation can give a sound reason why he should be allowed to live in a free country." T. Roosevelt
N5RMQ is offline
post #6 of 10 Old 02-18-2009, 04:55 PM Thread Starter
Bmel17
its benn on their for 2 yrs, so its not the culprit.
but if its electrical, they'll blame that and my amp and say no its just how they operate
08 HD Nightster
Bmel17 is offline
post #7 of 10 Old 12-05-2010, 04:51 PM
octopusgun
i just had this same code pop up. how did you fix yours?
octopusgun is offline
post #8 of 10 Old 12-05-2010, 07:28 PM Thread Starter
Bmel17
welcome to the forum! I just cleared the codes. It just reset and nothing ever popped back up. unplug your battery for 30 minutes or so. Mine never came back and never knew what the code actually was...?
08 HD Nightster
Bmel17 is offline
post #9 of 10 Old 12-05-2010, 07:36 PM
TheStigX
NVLD stands for natural vacuum leak detection
OPERATION
The Natural Vacuum Leak Detection (NVLD) system is the next generation evaporative leak detection system that will first be used on vehicles equipped with the Next Generation Controller (NGC). This new system replaces the leak detection pump as the method of evaporative system leak detection. This is to detect a leak equivalent to a 0.020" (0.5 mm) hole. This system has the capability to detect holes of this size very dependably.
1 - EVAP CANISTER
2 - NVLD FILTER
3 - NVLD PUMP
4 - VAPOR LINES
5 - FLOW VALVE
6 - TOP OF FUEL TANK)
It didn't seem that deep...
TheStigX is offline
post #10 of 10 Old 06-21-2011, 07:07 AM
brianarrr
Iron Maiden Fan
brianarrr's Avatar
Old thread, but it helped me today. I removed the charcoal filter for my tube fender install, at some point I had to turn the jeep on with the whole system disconnected to move it. Put everything back in minus the filter and had code P0499. Disconnected the battery for 30 minutes and code was gone. Thanks!
Black 06 Rubicon being rebuilt, RE LA 5.5" on 35s
Build thread:
brianarrr is offline
Misfire code P0301 & Fuel level code P0463 related? -OlllllO- TJ Wrangler Technical Forum 6 04-28-2010 02:55 PM
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 08:46 AM
Engine Code P 304, Engine code P0304 JeepinRRT TJ Wrangler Technical Forum 4 09-23-2009 09:26 AM
YJ EVAP solenoid code/AC Code, Stalling/Dying when coming to a stop issues fyallm YJ Wrangler Technical Forum 16 07-13-2009 07:33 AM
sorry for being the 900th trouble code post but i couldnt find what code 24 was shurd25 YJ Wrangler Technical Forum 3 03-24-2007 08:25 AM
