coasting in neutral w/ a manual...good or bad for the engine - JeepForum.com
post #1 of 74 Old 08-13-2010, 08:57 PM Thread Starter
will21190
I have a 5 speed and was wondering if this would hurt the engine...im trying to save on gas, and i figured it woul help just a lil.
will21190 is offline
post #2 of 74 Old 08-13-2010, 09:01 PM
Sweeney
It won't hurt a thing.
Sweeney is offline
post #3 of 74 Old 08-13-2010, 09:02 PM
mrcrwly
lol
WhiskeyTangoFoxtrot...
Rescue Green Jeep Club Official Member Let the mods begin! 07 JK Sahara Loaded, 4.10s lim slip 4" RC lift 16 34x10.50 LTB Interco Swampers. Pro-Josh Evap relocation, Skid Row motor/trans skid, Build in the works...
mrcrwly is offline
post #4 of 74 Old 08-13-2010, 09:02 PM
YJteen
x2 I do it a lot when im goin down a hill.
95 Rio Grande YJ. Power generously provided by 4 angry squirrels and a 20 gallon squirrel feeder. Sitting on 31x10.5 ATs with AR wheels
Yes I'm 20, Yes I like Jeeps, Yes I do not know everything
Originally Posted by GrandLaredoWJ
You should be fine with the axle setup, just as long as you don't beat on it as hard as you would looking at a Playboy magazine, the d30 and d35 should hold up.
YJteen is offline
post #5 of 74 Old 08-13-2010, 09:10 PM
adudenamedsean
I was under the impression that coasting in gear actually saves more gas because while in neutral it requires fuel to keep the engine running. On the other hand, coasting in gear just uses the engines resistance and shuts off the fuel. Or am I totally off base here?
adudenamedsean is offline
post #6 of 74 Old 08-13-2010, 09:17 PM
wushaw
Rockin jeep
wushaw's Avatar
Turn the key off and see what it does.
OP; Coasting in neutral for short distances won't hurt anything.
wushaw is offline
post #7 of 74 Old 08-13-2010, 09:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No engine damage will occur from this.
Not enough savings will be noticed to make it worth doing, so don't bother. See below.
On fuel injected vehicles, the air fuel ratio is determined by the amount of air passing through the engine (along with many other factors) so as long as the RPMs are happening fuel will be provided.
Coasting out of gear or "free-wheeling" is a lousy habit to develop. Should the need to accelerate or decelerate suddenly happen you'll invariably struggle to figure out what gear to be in or how to quickly respond.
You should ALWAYS be in the correct gear for the speed of the vehicle, no exceptions.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 74 Old 08-13-2010, 09:29 PM
adudenamedsean
Gotcha. Thanks for clearing that up, Max.
post #9 of 74 Old 08-13-2010, 09:31 PM
Sleeperman
I've been driving vehicles with a standard tranny for nearly 40 yrs, and agree totally with Mean Max. Plus, engine-braking is a wonderful thing when trying to time traffic lights!
Here, at 4900 ft above sea level, on pure gas, 15-17 mpg combined city/highway in a 2001 5-speed, 4.0L TJ is easy.
Sleeperman is offline
post #10 of 74 Old 08-13-2010, 09:43 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Off base? yep...
Knuckelhead is offline
post #11 of 74 Old 08-13-2010, 10:14 PM
RUBtjICON
My Jeep slows down when I put it in neutral. It wont coast/free wheel for chit.
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline
post #12 of 74 Old 08-13-2010, 11:51 PM
LuckRider
LuckRider's Avatar
Originally Posted by Knuckelhead View Post
Off base? yep...
That is odd because there was an article in car and driver or some other car magazine I read that too on that myth specifically. They had an engineer from Toyota say that any vehicle produced after 1995 would benefit most from being in gear because it would use 0 fuel to keep the engine alive and you need fuel to keep the engine at idle when coasting. I don't remember 100% what he said about carb engines, but I believe it was something to the effect of it using fuel proportional to the RPM of the engine.
Maybe that Toyota engineer was mistaken.
Anyway, the point about always being in the right gear is what I have learned and stick to. It was first taught to me by my dad many years before I started driving (when I was learning about how manual transmissions work and shifting), then reinforced by many others over the years.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #13 of 74 Old 08-13-2010, 11:52 PM
BYuen
BYuen's Avatar
See that's what I thought too I think I got it from that same article.
BYuen is offline
post #14 of 74 Old 08-14-2010, 12:14 AM
carnuck
1984 J-Series Truck
I was driving a 5 ton Dodge flatbed from Kamloops, BC to Vancouver and there was a looong stretch of road with a steep downhill. Even with manual 5 speeds and a 2 speed rear axle it had a top speed of 55 mph boot to the boards, so I put it in neutral for Mexican Overdrive (we were hauling an asphalt ripper for a D9 cat)
After about 3 miles of coasting, we discovered (the hard way) that a bolt had fallen out of the trans, and the lack of oil caused 2nd gear synchro to weld engaged.... at 70 mph. Ever ride a bucking bronco? Piece of cake compared to this ride! Quickly thinking, I jammed in the clutch and tried to shift (loads of clashing noises, but no synch) but it stopped bucking till I let the clutch out again.
I had to hold it in till we coasted all the way down to Merritt. We tried to break it loose, but gave up and started heading the rest of the way home. Almost to the top of the pass, the clutch blew up and I spent 3 1/2 hours with my foot on the brake, awaiting a tow truck big enough to handle the load (they sent a 1 ton, a 3 ton, then finally the semi hauler and IT was working hard on the trip home!)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #15 of 74 Old 08-14-2010, 12:24 AM
buddyfilek
Think about it. If you take it out of gear and coast your Jeep idles i.e. uses gasoline. Leaving it in gear lets the momentum of the jeep keep the motor turning through the wheels. Beyond fuel consumption, you have to consider that without engine braking you use up more brakes and you aren't in complete control of the vehicle. Any driver worth their salt keeps it in gear unless they are at a dead stop.
buddyfilek is offline
better economy , better mileage , coasting , driving , in gear , manual , miles per gallon , mpg , neutral
Installing a neutral safety switch for remote start? 2003 manual 4.0. TheMightyGoat TJ Wrangler Technical Forum 34 12-05-2010 03:16 PM
Click/ gargle noise when i drop the clutch in Neutral or when turning off in neutral JJeeper09 TJ Wrangler Technical Forum 1 08-11-2010 09:50 PM
Noise from left wheel while coasting in neutral mudsmorefun YJ Wrangler Technical Forum 4 11-14-2009 07:05 PM
Coasting in Neutral BM20 TJ Wrangler Technical Forum 41 07-10-2008 04:47 PM
Squeak in Manual Tranny when in Neutral newjob1975 JK Wrangler Technical Forum 8 04-11-2007 07:09 PM
