clutch wont engage and jeep wont fire
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
got stuck in a mud hole sunday and my clutch stopped working
got winched out and my jeep wouldnt start got it started and promptly over heated and blew my rad i got it towed home and put a new rad in changed the oil and she wouldnt start so i got my starter rebuilt (it had no brushes left and the solinoid was shot and filled with mud) just put the new starter in fire it over and she started right up clutch still wouldnt engage so i turned it off to add more coolant and now it wont fire again? any thoughts? im pretty sure the clutch is filled with mud as it was just put in last thursday but any input would be great its a 01 with a 4.0 and nv3500 (also brand new thursday) help
#2 |
Jeep
Did you press in the clutch when you were sunk in the mud?
Your radiator was clogged with mud, that is why you overheated.. Make sure you have a gallon of coolant and a gallon of distilled water in your cooling system. No more no less.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#3 |
Do it right or not at all
![]() Join Date: Jan 2003
Could be a damaged crankshaft position sensor mounted to the flywheel housing at the top on the driver's side. Never EVER depress your clutch pedal when in deep mud, doing so allows mud to flow in between the clutch disk and flywheel. You should change your tranny gear lube too.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#4 |
so do i have to seperate the engine and bellhousing to fix this?
#5 | |
Jeep
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
