Clutch - transmission really need help - JeepForum.com
post #1 of 14 Old 08-09-2017, 09:02 AM Thread Starter
OLDERGUY
2004 2.4L WRANGLER TJ
Driving along and it just stopped. High rev on rpms.
Towed it home and replaced the clutch.
Bled master and slave cylinder.
It will start, but won't move. I can put it in any gear and nothing.
What should I do next besides shoot it or me?
OLDERGUY is offline
post #2 of 14 Old 08-09-2017, 09:08 AM
TheBoogieman
Dead Jeepers Club
TheBoogieman's Avatar
It just stopped how? More details.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 14 Old 08-09-2017, 09:28 AM
jeff_in_rc
Transfer case shifter bumped and in neutral?
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is online now
post #4 of 14 Old 08-09-2017, 11:11 AM Thread Starter
OLDERGUY
Additional details.
In 5th gear driving. It acted like it was taken out of gear.
No transfer case not in neutral.
Anyway drug it home and put in clutch and bled master cyl and slave cyl.
You can shift it through the gears without depressing the clutch. Start it up and it will run but does not move.
OLDERGUY is offline
post #5 of 14 Old 08-09-2017, 11:34 AM
jeff_in_rc
I will lean towards a broken drive chain in the t-case then.
have you tried 4 wheel hi or low for giggles?
post #6 of 14 Old 08-09-2017, 11:38 AM Thread Starter
OLDERGUY
No have not tried that. I guess pull it off and open it up? Tcase not really hard to pull
OLDERGUY is offline
post #7 of 14 Old 08-09-2017, 12:17 PM
JEK3
JEK3's Avatar
The drive chain is only used for transferring power to the front axle. Rear is a straight shaft with essentially a splined sleeve that either couples power directly, or through a planetary gear.
Sounds like you could have a broken shaft somewhere. Question is whether it's in the transmission or the transfer case.
JEK3 is offline
post #8 of 14 Old 08-09-2017, 02:10 PM
XJ_jeepin_06
XJ_jeepin_06's Avatar
I would think if you can shift into gears without the clutch and the engine running your transmission input shaft is broken... weird to say.You could always drop the trans and see if the input shaft spins the output shaft. That would tell you where the break is.
1997 TJ. Red. 4.0/AX15/NP231 SYE. D30/S35. Lokka/E-Locker. 4.10s. JK Rubi Tires/Wheels.
Antirock.
XJ_jeepin_06 is offline
post #9 of 14 Old 08-09-2017, 02:21 PM
jeff_in_rc
I stand corrected, thank you!
post #10 of 14 Old 08-16-2017, 04:43 PM
jeff_in_rc
So OLDERGUY, have you found the problem yet???
post #11 of 14 Old 08-16-2017, 10:08 PM
MDTJ
MDTJ's Avatar
I'd pull the TC before pulling the trans, and see if the transmission output shaft turns. That's easier than pulling the trans to start with.
Good resources:
MDTJ is offline
post #12 of 14 Old 08-16-2017, 10:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Maybe the transfer case shifter linkage slipped out of adjustment and even though the lever says it's in 2Hi it's really in Neutral. When that happens you can't shift the transfer case into 2Hi, 4Hi,or 4Lo.
Jerry Bransford is online now
post #13 of 14 Old 08-17-2017, 06:16 AM
JEK3
JEK3's Avatar
But you have to go through 4Hi to get to neutral. Wouldn't you feel that happen?
JEK3 is offline
post #14 of 14 Old 08-17-2017, 09:46 AM
Jerry Bransford
Administrator
That depends on how familiar anyone is with shifting the transfer case, and at what point the linkage decided to slip out of adjustment while it was being shifted.
