Clutch or transmission - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clutch or transmission
GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Artec JK Under Armor BellypanEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-26-2014, 07:31 AM   #1
Adamlson
I have a 06 tj 4 cyl. I was driving when I lost all acceleration power and rpm s started jumping high. I idled home. Yesterday went to start it put it in gear,let off clutch giving no gas jeep idled forward same thing in reverse. Jeep should kill when letting off clutch and giving no gas but it keeps running . What is going on transmission or clutch or something else please help ?
Adamlson is offline   Reply With Quote
Unread 07-26-2014, 08:07 AM   #2
brokenyoujoint
Well if your not in gear and the jeep creeps fwd it sure sounds like your clutch. Happened to me once. When u tear it apart to see what failed you'll just end up replacing the whole clutch anyways cuz it just makes sense. Drain and check your tranny fluid. A Lil silver is OK. If it looks like dexter butchered r2d2 then suspect something worse.
brokenyoujoint is offline   Reply With Quote
