clutch or slave/master cylinder problem. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > clutch or slave/master cylinder problem.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 12-05-2009, 11:45 AM   #1
turtle17
hey guys, this is my 1st post but iv been a longtime site stalker.
i drive a 97 4.0 wrangler. a few days ago i went to start my jeep, and when i pushed the clutch in to start it up (it was pretty tight). it "popped" and the clutch peddle lost tension for about 3/4 of the push, and the last 1/4 has some tension. when i push it the floor, and try to start it, the engine will try to turn, but only get like a 1/2 ot a 1/4 turn and quit. im thinking its the slave and master cylinder, but im not sure, iv never had to deal with a clutch before soo im going to youu guys (the pros) for some tips.
turtle17 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2009, 12:05 PM   #2
Rubiscon
Hows the fluid level in the hyd clutch?
More than likely its the actuating cyl in the tranny... looks like you blew a seal. (Or is that just mayonnaise on your lip?) LoL
Rubiscon is offline   Reply With Quote Quick reply to this message
