Clutch Rattle , 5 Speed Guys. - JeepForum.com
post #1 of 7 Old 06-23-2012, 08:22 AM Thread Starter
gtospeeding
I have an 2002 tj 5 speed, when I turn the jeep off in neutral something is rattling in the transmission area . But when I turn it off with the clutch in no rattle
any ideas what's rattling and how to fix it?
gtospeeding is offline
post #2 of 7 Old 06-23-2012, 08:40 AM
n5xl
The only thing that comes to mind between the two situations is that the throwout bearing is under pressure in the latter situation and cant move on the fork.
99TJ,AX15,2"ACOS,33BFGKM2
99XJ,AW4,2"OME,JKSShortArms
98XJ,AW4,3"ACOS/Shackles/AASYE/TomWoodsDS
n5xl is offline
post #3 of 7 Old 06-23-2012, 08:51 AM
MrDubbe
My 03 does the same thing. It rattles while in neutral with the clutch out and with the clutch in it sounds fine. To me it's normal but it does make jeep sound like a tractor.
MrDubbe is offline
post #4 of 7 Old 06-23-2012, 09:44 AM
alex211
1995 XJ Cherokee
Completely normal bro.
95 xj bone stock for now
alex211 is offline
post #5 of 7 Old 06-23-2012, 09:50 AM
Necko2529
I would agree with all the posts above as I experience the same thing with my nv3550.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #6 of 7 Old 06-23-2012, 01:24 PM Thread Starter
gtospeeding
so there is no solution for the rattle?
post #7 of 7 Old 06-23-2012, 01:33 PM
alex211
1995 XJ Cherokee
There's nothing to fix
alex211 is offline
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 01:39 PM
What is the YJ's N.R.S. (normal rattle speed) rain-gler Wrangler General Discussion 9 02-07-2009 01:04 AM
4.0 5 speed trans rattle when clutch out Deere9670 TJ Wrangler Technical Forum 3 01-27-2009 11:46 AM
Low speed rattle akell215 TJ Wrangler Technical Forum 1 07-10-2008 07:38 PM
AX-15 rattle at high speed Big92Jeep YJ Wrangler Technical Forum 7 02-11-2002 10:59 AM
