Clutch problem - JeepForum.com
post #1 of 10 Old 06-28-2010, 05:03 PM Thread Starter
darren2569
Clutch problem
Ok. Ive used the search and am more confused than when i started. Ever since I got my jeep (2002 TJ 5spd) i can hear a little rattle when in neutral that goes away when i press the clutch. I've read that its just the throwout bearing, and Ive read that its not.
Today I went to work, everything is normal. When I go to leave, the pedal feels funny, like the cylinders are going. It still drives fine but the point where the clutch engages seems a lot closer to the floor than it was. I checked the clutch fluid level and its fine. I also noticed that my rattle when in neutral has gone away. Oh and the clutch creaks from underneath when I press the pedal (been doing that for a couple months)
I have no idea what this could be. Any help would be most appreciated.
I did read someone had the throwout bearing come apart and stopped the pedal going down as far so I'm wondering if that's it?
The JK driver blonde bing-bing fingered me!!!
darren2569 is offline
post #2 of 10 Old 06-28-2010, 05:11 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If your throwout bearing came apart, it would look like this.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 10 Old 06-28-2010, 05:26 PM Thread Starter
darren2569
WOW. any way of checking without pulling the tranny or would I hear the parts rattling around in there still? Apart front the creak when I press the clutch, theres no bad noises at all. Its actually quieter than its ever been.
post #4 of 10 Old 06-28-2010, 07:29 PM Thread Starter
darren2569
Ok Just took it for a drive and it seems fine except for the point where the clutch engages seems lower, probably about 1/3 to 1/2 of the way up from the floor and the pedal feels a little softer too. I guess if its working I should just not worry about it? I'm just kinda anxious because we're supposed to go wheeling this weekend.
post #5 of 10 Old 06-28-2010, 07:59 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Well, there is no way to check anything inside the bellhousing without removing the tranny. The pedal travel difference is due to something changing which altered the amount of fluid required for operation. It's needing to travel farther (longer stroke) to do the same job it's been doing, and the longer stroke means that it's moving more fluid. Simple hydraulic theory, in the most elementary sense.
Why? I'm not able to say with certainty what's causing it, but it would be best to thoroughly diagnose the issue before wheeling.
My money is on the throwout bearing, based on your descriptions.
Max
Mean Max is offline
post #6 of 10 Old 06-29-2010, 06:20 AM Thread Starter
darren2569
I guess I know what Im doing tonight Any Idea how long it'll take? I'v replaced a bunch of clutches (mostly on FWD cars) but never on a Jeep. And its been a long time since the last one.
post #7 of 10 Old 06-29-2010, 06:27 AM
nikeo02
At least for me, jeeps are a lot easier than fwd cars. With the right tools, you can drop the tranny quick. No complications, about an hour and a half. But i have a lift...
nikeo02 is offline
post #8 of 10 Old 06-29-2010, 06:34 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
I have them out in an hour & a half in most cases. I pull the T-case & tranny separately. Many people pull them as 1 unit, it seems to not make a lot of difference time-wise but just personal preference.
Max
Mean Max is offline
post #9 of 10 Old 06-29-2010, 06:43 AM
lowicz96
1995 XJ Cherokee
Pulling the t-case makes the trans easier to manhandle back in if you do it in your driveway
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #10 of 10 Old 06-29-2010, 07:52 AM Thread Starter
darren2569
Cool I was gonna try that because I'm doing it by myself and I figured the only problem I'll have is wrestling the tranny/t-case back in. Splitting them will definatly help. Thanks for the help guys Im a lot happier now I know it doesn't take 12hrs like someone else told me.
clutch
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 05:31 PM
Clutch Problem 2003X TJ Wrangler Technical Forum 34 12-26-2009 07:04 PM
Another Clutch Problem Lendo YJ Wrangler Technical Forum 7 08-03-2009 02:48 PM
Problem with clutch disengagement after clutch replacement (94 YJ) cslots675 YJ Wrangler Technical Forum 0 05-17-2009 07:15 PM
Fan Clutch Problem...Please Help! 05 Rocky Mounta TJ Wrangler Technical Forum 2 06-16-2007 02:05 PM
