Clutch Pedal Clip Removal - JeepForum.com
post #1 of 8 Old 05-08-2009, 04:42 PM Thread Starter
pointblanke
I'm changing the clutch master cylinder in my 97 4.0, Everything is going great, except the pint that holds the master cylinder to the clutch pedal is held in place with some type of plastic clip. I'm afraid to just break it off in case I can't get a new one easily. Anybody know how to take this off?
"It's better to be dead and cool than alive and uncool" Harley Davidson and The Marlboro Man
pointblanke is offline
post #2 of 8 Old 05-08-2009, 04:54 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i thought it had a cotter pin up top on the inside?
RnEmOvr is offline
post #3 of 8 Old 05-08-2009, 05:11 PM Thread Starter
pointblanke
That's what the Hayne's Manual says. Mine has som sort of black plastic cap.
post #4 of 8 Old 05-08-2009, 05:16 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's been several years since I removed mine to remove the clutch system but I don't recall it taking more than a few seconds to get the clip off and it didn't break in the process.
Jerry Bransford is online now
post #5 of 8 Old 05-17-2009, 07:00 PM Thread Starter
pointblanke
The new one also came with the same clip. I pried the old one off and the new one snapped right on. The whole thing was pretty straightforward. Just got back from taking it out for a spin. Thanks for the help everyone!
post #6 of 8 Old 08-25-2011, 07:48 PM
yobeez
What about the clutch end? There is a plastic piece that is held in place by two plastic tabs. The tabs were cut off at the base of the piece on the old one.......do I need to do the same or are they designed to break when you first push the clutch pedal in?
yobeez is offline
post #7 of 8 Old 08-25-2011, 08:29 PM
yobeez
Anyone?
yobeez is offline
post #8 of 8 Old 08-25-2011, 08:44 PM
TJSunny1
I just installed my mopar master and slave last week. I thought that the two plastic tabs on the slave would break away but they didnt. I took the slave off again and cut them off at the pushing end so they were nonexistant and reinstalled the slave by just pushing it inreally hard while tightening the bolts. If you only cut the ends off after it is installed, you get an annoying clicking noise.
TJSunny1 is offline
Clutch Pedal soft, no resistance, does not engage clutch. Shivam YJ Wrangler Technical Forum 25 02-20-2017 03:10 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
c clip removal amajeeptour YJ Wrangler Technical Forum 2 07-07-2009 07:54 PM
Front clip removal jeepwrnglr92 YJ Wrangler Technical Forum 7 11-21-2007 12:23 PM
Clutch pedal clip? Dravintoad TJ Wrangler Technical Forum 3 08-25-2007 12:49 PM
