Clutch override, Dont clutch in water, i dont understand..help? - JeepForum.com
post #1 of 29 Old 10-29-2006, 07:37 PM Thread Starter
$lick
I dont understand the point of the clutch override system really, say your stuck on a rock, or mud, or anything, you will have to engage the clutch at one point to put the jeep back into gear.
any the theory of not depressing the clutch when you are going through water or mud i understand, but what happens when you get stuck? the clutch has to go in at some point to put the vehicle back to neutral to prevent stalling, or once again the clutch has to be engaged to either start the vehicle or put it back into gear when getting pulled out.
so im confused.. and i come to you all for help
explain these theories..and benefits of clutch override..etc please?
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline
post #2 of 29 Old 10-29-2006, 07:57 PM
daveg13
daveg13's Avatar
You start the vehicle in gear. Try it out, override the clutch interlock, put it in first, and turn it over. It'll start running as it starts to move. Really easy to do in 4L.
daveg13 is offline
post #3 of 29 Old 10-29-2006, 08:02 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I have to do that everytime I move my Heep right now... no clutch = running start everytime. (I use 2hi, and don't worry, it doesn't move very often).
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #4 of 29 Old 10-29-2006, 08:06 PM
dirtbagofva
2010 JK Wrangler
First off don't stop in water/mud and depress the clutch, sediment will get between the friction disc and the flywheel/pressure plate. Resulting in you having to replace the clutch.
If you are going through water and the water stalls the engine, you have 2 choices in getting out, restart the engine or get pulled out and then restart. If you have the clutch switch overridden you can put the tranny in neutral get the engine running and then shut it off. With the engine able to run put it into first and restart the engine, durring the whole process you never depressed the clutch. This is hell on a starter but it is easier and cheaper to replace them.
A popular misconception about a standard transmission is you have to use the clutch. It is only need to engage first gear with the engine running since most transmissions are synchonized. What the synchonizers alow you to do is shift on the fly without the clutch. I wouldn't recomend doing this as the grinding sound you will hear is the teeth wearing off. The secret is having the engine turning the speed at which the wheels are turning for that gear (2,3,4,5). in my old truck 2nd gear was about 10 mph and 3 was 15-18.
I hope that answered you question with out being too confusing.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline
post #5 of 29 Old 10-29-2006, 08:12 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Check my sig. Mean Green makes starters for this exact reason. Good stuff.
Once again, . I've found the "proper" engine speed for shifting with most gears is ~1900 RPMs. But, once you get out of the crap, you can use the clutch as you have come to know and love. Just DON'T use it while in the middle of a puddle.
Andy, KD8EIA
Grewe02 is offline
post #6 of 29 Old 10-29-2006, 08:12 PM
dyna
Clutchless shifting is fine in a real truck, I dont think the AX or NV will appricate it much. Its your trans though.
dyna is offline
post #7 of 29 Old 10-29-2006, 09:11 PM
Zice
Zice's Avatar
... where is the clutch overide?
not to sound like a n00b but I have never heard of it.
Zice is offline
post #8 of 29 Old 10-29-2006, 09:37 PM
dyna
Fuse panel behind the glovebox, bottom left 20 amp says something about auto trans bla,bla. put a fuse in and no more pushin clutch to start. remove fuse and you have to push clutch in to start.
dyna is offline
post #9 of 29 Old 10-29-2006, 09:42 PM
jzmtl
jzmtl's Avatar
Not something I would do as your synchros are now function as clutch since most of us can't rev match that well. And the grinding sound is the dog tooth in transmission failing to engage.
jzmtl is offline
post #10 of 29 Old 10-29-2006, 09:46 PM
SecondTJ
SecondTJ's Avatar
i thought synhconizers were so that you can downshift
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #11 of 29 Old 10-29-2006, 09:52 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
When 4-wheeling with stick, you can crank your engine in first gear without pressing down on clutch. The sheer power of cranking will start it in gear and get the Jeep moving forward. This is the way the Jeep Legend Mark A. Smith made it over the swamps in the Amazon jungle. You don't press the cluth when submerged in water, as it will damage the clutch.
Or, just buy a rig with AUTO.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #12 of 29 Old 10-29-2006, 10:21 PM Thread Starter
$lick
so basically i do the clutch overide, and i can start my jeep when its off in first gear if im stuck and it will go?
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
JKS Disco's
Axle specs:
Riding on:
33x12.50 BFG A/T
$lick is offline
post #13 of 29 Old 10-29-2006, 10:25 PM
msubrian
Don't forget that your starter has quite a bit more torque than your engine. Lots of folks use their starter to climb obstacles and what not.
2005 TJ, 5.5" RELA lift / 35"BFG mudders / Garvin tire carrier-bumper / Warn 9.5ti / Rokmen Mercenary bumper / 15" MT Classic II wheels / TJC heat reduction hood / Alloy USA axles/ and a partridge in a pear tree
Sponsored by:
msubrian is offline
post #14 of 29 Old 10-29-2006, 10:27 PM
msubrian
if you are stuck.....then you are stuck. There isn't much you can do at that point. If you start the car in gear without the clutch you just get a lot more torque, you start rolling as the key turns, and you won't jack your clutch up in the mud.
Sponsored by:
msubrian is offline
post #15 of 29 Old 10-29-2006, 10:36 PM
Zice
Zice's Avatar
Your serious? I never heard of that...
Zice is offline
need help dont understand tire size erhenriques TJ Wrangler Technical Forum 6 08-26-2009 02:20 PM
05 TJ - Clutch interlock override fuse wont override.. Grrr.. jbro507 TJ Wrangler Technical Forum 2 08-09-2009 07:08 AM
dont understand off roading? buZZBomb_ Wrangler General Discussion 52 01-09-2009 09:43 AM
dont understand t-case drop iwishihad1 YJ Wrangler Technical Forum 4 03-08-2006 01:44 PM
The more i search the more i dont understand Ol'Blue Jeep TJ Wrangler Technical Forum 4 02-22-2005 09:21 PM
