Clutch, Master or Slave Cylinder Problems??? - JeepForum.com
post #1 of 1 Old 09-14-2009, 04:32 PM Thread Starter
duha
I drive a '03 Wrangler SE with 70k miles. I replaced the clutch and flywheel about 6 months ago. I replaced the stock clutch with a LUK. My problem is the clutch pedal is squishy and does not engage until the pedal is about all the way out. Is it supposed to be like that? Do I need to replace the clutch hydraulics or is there a way to bleed the closed system?
duha is offline
Clutch Slave and Master Cylinder replacement jonner YJ Wrangler Technical Forum 13 08-03-2006 09:58 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
Master/slave clutch cylinder replacement 95 SaucerBoy YJ Wrangler Technical Forum 15 08-15-2005 04:13 PM
clutch master/slave cylinder Big Blue Jeep YJ Wrangler Technical Forum 4 06-07-2003 12:02 AM
Help: Clutch Master Cylinder/Slave Connection Kev YJ Wrangler Technical Forum 6 08-09-2002 11:19 AM
