#1 | |
Clutch Master Cylinder Install
Was just wondering if anyone could give me some tips on replacing my '97 TJ Master Cylinder Clutch.
I have the new part(s) and will be replacing it in a few hours (gotta sleep & wait for the sun )I havn't been able to find any writeups online so i figure i'd ask the boards.. Never had to replace the clutch before so if there are any tips ppl can give ahead of time i'll deffinantly take em I imagin i'll have to bleed some lines, any suggestions on that? The master cylinder says it just uses brake fluid so i'll have to pick that up I guess.... Other than that I was told it was a fairly simple install... I just ordered a new one from autozone btw... I don't have the replacement kit from Jeep... Didn't know they sold one to tell the truth until after I bought the master cylinder seperate ![]() Thanks In Advance! ~James
'97 TJ 5spd 4Banger, 3" OME , JKS QD's & Adj. Track Bar, 31" Kuhmo Venture MT's, Congo Cage Roof Rack, Uniden CB, etc. |
#2 |
It is just like replacing a master cylinder...bolt it in, gravity bleed it with the lines loose, tighten the lines and bleed the slave cylinder. It's pretty easy, done it on 10 differn't vehicles...their all the same.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word." Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7 |
#3 |
Bench bleed the master before installing it.
It should come with instructions and a couple pieces of tubing. Fred
[b]Base[/b] - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp) [b]Suspension[/b]- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar. HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56 [b]Misc[/b] - Tera 2wd lo. [b]Tires[/b] - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks. [b]Recovery[/b] - Warn XD9000i |
#4 |
Thnx for the tips, I'm starting the install now
I figure I got today to figure out and if I do screw up I have till the en d of monday to fix it Looking uder the hood it looks as thought the hardest part is going to be bleeding the line. I guess there are only 2 bolts for the master cylinder cia the firewal... And I RELLLY wish it did come with instructions, cause atm I'm just looking at how the current one is comming apart and doing the opposite with the new one
#5 | |
MY $.02
#6 | |
We wouldn't have installed one any other way. ![]() Fred
#7 | |
Either way you go you need a friend with a stong leg who has some time to kill. ![]()
#8 | |
![]() Fred
#9 |
Bench bleeding a clutch master cylinder? I guess you can do that....never heard of it myself.
#10 | |
![]() Still, a master cylinder is a master cylinder none the less ![]() MERRY CHRISTMAS EVERYONE !! ![]() Fred
#11 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
