clutch master cylinder - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > clutch master cylinder
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 01-09-2014, 06:08 PM   #1
mgoff32
does anybody have a link for how to change out the clutch master cylinder? I will be changing mine out tomorrow morning after I get out of work. one other thing is does anybody know what size flare wrench I need to get for the clutch line removal?
mgoff32 is offline   Reply With Quote
Unread 01-09-2014, 07:14 PM   #2
TMLoftis
1978 CJ5
There is a write up somewhere on jeepforum. I'd just do a good searching.
I bought a complete system on mine that came with a master, slave, line and was pre bled so I don't know the specifics of that.
But it was two bolts above the clutch petal. I believe 13mm but I may be wrong. And also a plug and a cotter pin.
TMLoftis is offline   Reply With Quote
Unread 01-09-2014, 07:30 PM   #3
mgoff32
Thanks man
