Clutch Issue FINALLY Resolved... Hopefully. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clutch Issue FINALLY Resolved... Hopefully.
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 04-23-2015, 11:48 AM   #1
CoachDad
I bought my '03 X with a fragged clutch. I replaced it with a LUK kit, and then had to swap the T/O about 800 miles later. Well, after that, plus a new master/slave cylinder combo, clutch fork, pinion ball, and fluid exchange for Mopar 3500, I would still get pedal chatter and hard to engage shifting after only a day or two of driving.
A total clutch failure caused me to drop the trans for a 3rd time this year. My new T/O bearing was in 3 pieces, and the slave boot had torn and the rod had completely ejected. Low and behold, I finally found the root cause.
The main drive retainer (pictured) had lost it's sleeve, leaving just the mounting base in place. This has caused the T/Os to suffer and come apart due to looseness, and has cause me all of my headaches.
I am posting this for the benefit of any others who may have similar issues, and can't find the cause. It's easy to miss, since it breaks off cleanly at the base. I'll be putting it back together, and expect it to be honky-dory.
CoachDad is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 11:59 AM   #2
bbradUSMC
Good to go
bbradUSMC is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 12:05 PM   #3
jdunk813
I actually need to drop my trans as well. I replaced the clutch, pilot, throw-out bearing but chose not to replace the seal to the input shaft of the transmission. It leaks out the front coating my clutch in trans fluid every so often. I did remove that piece to inspect it. Interesting that it would break cleanly at the attachment point. What would have caused this to happen?
2004 Wrangler Willys Edition
jdunk813 is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 12:53 PM   #4
CoachDad
I'm not sure what would cause it, but I can offer a guess. When I first dropped my trans, I found the clutch friction disc to be in fair shape, but the fingers on the pressure plate were badly worn, and a couple were missing. The T/O was busted up, and the clutch fork had come displaced and had a deep gouge cut in it. Given all of this, I suspect that the T/O bearing had caught in the pressure plate fingers, and had jerked the clutch fork so violently that it torqued the sleeve portion of the retainer and broke it off. That's just a guess, but it's my story and I can tell it however I like.
Unread 04-23-2015, 03:54 PM   #5
JWebber
My clutch fingers looked broken when I replaced mine, What caused it was a worn out and grooved front bearing retainer shown above. Granted I never replaced it after my first clutch change out. So I went 125K further and it damaged my clutch fingers due to it binding and not fully releasing. Replaced all and clutch is way better than before.
JWebber is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 06:53 PM   #6
Opihi59
from here it gets rough
Opihi59's Avatar
I think that's a pretty good forensic synopsis of the failure. I'd believe that one/do believe that one.
Buying those long-snout front bearing retainers, you'd think they were made from platinum. Sometimes you can find them on ebay reasonably cheap used, but most have to buy them from Crown new at about $150 plus.
Throw out bearings--there have been a ton of failures in those since they've started using plastic composite body rather than cast iron. They come in the clutch kit box, so Jeepers seem to feel compelled to use them. It is best to purchase one separately from the kit made of a cast iron body. I have saved one of my old cast iron ones and have this idea that somehow I'll be able to pull apart the composite one, and install that bearing on the cast iron body.......won't know til the next time I do a clutch, unless some enterprising Jeeper does it first and posts it up on the forum.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is online now   Reply With Quote Quick reply to this message
