Quantcast Clutch interlocking bypass - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clutch interlocking bypass
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 04-24-2007, 07:56 PM   #1
unlimited4x4
I am having trouble with the clutch interlocking system. It is stopping my jeep from starting. I have bypassed it to figure out the problem by inserting the fuse. When I put the fuse in, the 4wd light comes on. I know the vehicle is not in 4wd. The manual also cautions the bypass should only be used in 4low offroad for a limited time. What damage could be done if i bypass this interlock? It seems like it serves purely as a safety function. Anyone know if operating with the bypass in place will cause a problem or does chrysler place all the limitations on it so you don't use it regularly, to make sure you don't start your jeep in gear and run someone over?
Also, Where is the clutch fluid check? I can't find the darn thing. (2005 TJ)
Thanks,
Unlimited 4x4
unlimited4x4 is offline   Reply With Quote
Old 04-24-2007, 08:30 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
NO damage will or even could be caused. That disclaimer is only from their nervous lawyers afraid you'll kill someone by accidentally forgetting to start your Jeep in neutral or with the clutch down. The clutch fluid reservoir is next to the master brake cylinder and brake fluid reservoir.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 04-24-2007, 08:46 PM   #3
jcm11881
This will sound like an ignorant question. Does the clutch take DOT 3 fluid? I see the cap next to the master cylinder calls for DOT 3. Is this the clutch? Or am I confused?
jcm11881 is offline   Reply With Quote
Old 04-24-2007, 08:47 PM   #4
amp77
I've bypassed this on every vehicle I've owned that had one. Ah, if it were only as easy for all the rest of them as on a TJ!
I like to start up the Jeep without having to jump in and push a clutch pedal. I can just reach in with the key and turn it over - I always leave it in N when it's parked.
amp77 is offline   Reply With Quote
Old 04-24-2007, 09:49 PM   #5
unlimited4x4
Thanks for the responses. Also, Is the interlock system the sensor at the top of the clutch pedal? Is it easy to replace, or is it some complicated gizmo I should leave for a real mechanic?
Old 04-24-2007, 09:50 PM   #6
Jerry Bransford
It's a simple on-off switch. Cut the wires to it and splice them together.
Getting Savvy...
Glock Forum
