clutch click - JeepForum.com
post #1 of 17 Old 09-10-2017, 08:49 PM Thread Starter
Kristian_Burns
clutch click
Has anyone ever heard of this? I will include a link to the video. The video is not my jeep however it is making the same noise when pushing and releasing the clutch. Doesn't matter if the engine is running or not. It seems to be noticeable after driving around a while once things are "warmed up".
Thanks!
Video:
Kristian_Burns is offline
post #2 of 17 Old 09-11-2017, 06:53 PM Thread Starter
Kristian_Burns
Anyone? It seems to be getting worse
post #3 of 17 Old 09-12-2017, 12:42 PM
TJnBC
The spring on the Throwout arm for the clutch might have come off or was never installed? I believe it is called a return spring (maybe someone will correct me).
Either that or the Throwout bearing or pressure plate. Since your engine is off there are only a small number of culprits if you are pressing the clutch pedal and it is making that noise.
2006 LJR...the madness begins again
TJnBC is offline
post #4 of 17 Old 09-12-2017, 12:45 PM
TJnBC
also take a look at the firewall where the Clutch pedal enters/exits. Maybe something is not lined up and bashing against the firewall
TJnBC is offline
post #5 of 17 Old 09-12-2017, 03:50 PM Thread Starter
Kristian_Burns
Ive been reading and found there is a clip or spring that needs greasing after you take the starter off you are able to see it?
post #6 of 17 Old 09-12-2017, 04:06 PM
TJnBC
you may be able to see it, but you wont be able to grease most likely without taking apart.
I would check the Firewall first. There is a piece that needs to move through the firewall when clutch pedal is pressed. Sometimes it doesn't line up in the hole in the firewall, and clicks/clanks against it every time.
TJnBC is offline
post #7 of 17 Old 09-12-2017, 04:14 PM
TJnBC
they are probably referencing the Fork and the one ends pivot on the pivot ball. That should have some light grease on it. Don't think that's your issue though. You wont be able to get to the inside of the fork to grease that without removing bell housing
TJnBC is offline
post #8 of 17 Old 09-12-2017, 04:27 PM Thread Starter
Kristian_Burns
It is definitely in the transmission. Just has my sister push the clutch a couple times and I could hear and feel it clicking on the transmission. Can I still drive it like this?
post #9 of 17 Old 09-12-2017, 04:54 PM
TJnBC
that's a judgement call for you to make. I tend to fix things like this before they become worse. IF indeed it just needs some grease, I don't think it will hurt it to drive. I am just not sure if IT IS that....could be other things until you take it apart. It doesn't involve a whole Clutch replacement but you need to separate the bell housing to get in there.
TJnBC is offline
post #10 of 17 Old 09-12-2017, 05:10 PM Thread Starter
Kristian_Burns
Understood. If it does just need some greasing. By taking the starter off I won't be able to get to it? I would have to pretty much take off the transmission?
post #11 of 17 Old 09-12-2017, 05:23 PM
TJnBC
If you look at the second picture I posted there is no way to get an arm into the Bell housing to grease that inside....even ET couldn't.
TJnBC is offline
post #12 of 17 Old 09-12-2017, 05:38 PM Thread Starter
Kristian_Burns
How hard is it to do?
post #13 of 17 Old 09-13-2017, 10:59 AM
TJnBC
is it HARD ? No. Is it time consuming, yes. If you can take off a bolts and remember where they go you can do it. With that being said, you will need a proper jack , some jack stands , basic tools.
The tcase skid will have to be removed , so you will have to support the transmission /tcase before you remove the skid as the Tcase is attached to it. Make sure you remove the Trans mount nuts prior to removing the skid plate. The rear driveshaft should be removed as well.
Then you have to separate the Bell housing from the Tranny...the top 3 bolts can be a pain because it is pretty tight in there. Separating the two may be difficult too , and lining up the output shaft to pilot bearing...a tranny jack really helps to line things up.
I would suggest Youtubing it first if you have never attempted. Having someone else to help would be ideal too
TJnBC is offline
post #14 of 17 Old 09-13-2017, 11:05 AM
TJnBC
check this link out...see if you can tackle this
https://www.4x4xplor.com/clutch.html
TJnBC is offline
post #15 of 17 Old 09-13-2017, 01:39 PM
MrSmiley
My jeep has made that noise since i bought it... 3 years ago. Always driven fine with zero issues engaging the clutch through any gears. And that is both with the original clutch and the clutch I put in it last year. You should be fine.
Certified Web Wheeler
MrSmiley is offline
