Quantcast Clutch bypass Fuse - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clutch bypass Fuse
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 03-24-2007, 07:52 PM   #1
thismust
Clutch bypass Fuse
So i have an 06 rubi LJ and went to put the 10 amp fuse into the Clutch bypass location and i felt it wasnt grabbing. I look into the location and it doesnt look like there are connectors in the fuse box to accept the fuse.
Do i have to take that fuse box off and install connectors? something seems a little goofy here. wtf
thismust is offline   Reply With Quote
Old 03-24-2007, 10:02 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 03-24-2007, 11:11 PM   #3
SecondTJ
I did this to mine a while back, i put the fuse in and started right up without the clutch. Also worked on my friends 99 and 02. There was nothing else to it, just stuck the fuse in there. As simple as can be.
I did read somewhere the this mod doesn't work on newer TJs, ( i wanted to say it was 05-06, but am not 100% on which years)
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla, Chicago Electric 10k winch
'99 Z28 M6, some goodies
'94 'Vette, A4 all stock
SecondTJ is offline   Reply With Quote
Old 03-25-2007, 05:25 AM   #4
06slvrrubi
Lovin' Life
06slvrrubi's Avatar
The mod does work on 05's, I've done it to mine. Couldn't tell you though if it works on 06's. Make sure you are looking at the right slot. Could it maybe be one to the left or right or up or down from the one you are looking at? Are there any others that are blank right near the one you are looking at, but DO have connectors in them for a fuse? I know that on my 05 there is a blank spot with nothing in it, just like you are describing, right beside the ctual clutch bypass fuse spot. I use it to hold the "spare" fuse that I'd use for the bypass if I ever needed to.
06 Rubicon
PICTURES
Check out the other vehicles in my Photobucket too!
06slvrrubi is offline   Reply With Quote
Old 03-25-2007, 07:06 AM   #5
RWB214
If you're interested in how I did this on my 99 XJ, read on..
There is no clutch bypass fuse on the XJ's so I found the clutch interlock switch down by the clutch pedal, ran some 16 gauge speaker wire to a switch, and spliced it into the clutch interlock switch. With the switch on, the Jeep starts sans clutch, Switch off, everything back to normal...
RWB214 is offline   Reply With Quote
Old 03-25-2007, 07:26 AM   #6
ysalriz
The mod does work on 05's, I've done it to mine. - 85fiero
I know that on my '05 Rubi the clutch bypass is in the underhood fuse box (per owners manual), and there are no connectors for it. So I have no way of starting without the clutch unless I have it in 4Lo. The owners manual says to stick a fuse into the slot, but there's no wires in the slot to grab the fuse..So I'm SOL on that area. If any of you know a fix, please let me know.
[SIZE=1][FONT=Arial][COLOR=White]'05 White Rubicon[/COLOR]
4.0L 6 Speed
[/FONT][/SIZE]
ysalriz is offline   Reply With Quote
Old 03-25-2007, 07:50 AM   #7
bpetry
The reason there's no fuse in the Rubi is because it automatically defeats the clutch in 4-lo, no need for it.
Regards,
Brian Petry
Springboro, OH
bpetry is offline   Reply With Quote
Old 03-25-2007, 08:55 AM   #8
SecondTJ
hm, so there is a marked location called "clutch bypass" for the fuse?
I put my fuse in what was labeled as "Auto Trans".
it was in the fuse box behind the glove box, bottom left.
Old 03-25-2007, 09:07 AM   #9
thismust
Sound like YSALRIZ is right. Must be a Rubicon thing. It still would be nice to be able to reach in and start it while working on it without being in 4 low
oh well
thanks everyone
Old 03-25-2007, 09:11 AM   #10
Pipedrummer
mine doesn't start in 4lo without the clutch being depressed, should it? (04 sport) or is this just a rubi thing?
Solar Yellow '04 TJ Sport, RE 3.5" Standard Kit w/ GEN 2 Discos, 33x12.5R15 Cooper Discoverer STT's on Black Crager D Windows, OME Shocks and Stabilizer, LOD Xtreme Duty Rear, Jeeperman Front w/ Pre-Runner Bar, Viair Constant Duty OBA - Front & Rear Quick Air Discos, Firetruck Air Horn, Galls Siren w/ PA, CARR Rotabar w/ KC Long Range Lights & KC Driving Lights, KC Fogs, Superwinch 9000lb, Viking Synthetic Line, Optima Yellow Top
Pipedrummer is offline   Reply With Quote
Old 03-25-2007, 09:18 AM   #11
ysalriz
I think it's just a Rubi thing. My last TJ ('02 X) had a fuse insert inside of the glovebox fuse panel and it would start in any XFer case setting without the clutch, but without the fuse inserted would not start in any without the clutch.
4.0L 6 Speed
[/FONT][/SIZE]
Old 03-25-2007, 10:42 AM   #12
SecondTJ
Its only a feature on Rubi's
Glock Forum
