Quantcast Clutch Bypass?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clutch Bypass??
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 03-09-2008, 09:04 PM   #1
QuickSilverCon
Clutch Bypass??
So when I was out playing around the other day I realized i could start without pushing the clutch in when I'm in 4Lo.
Is that normal? Is it just a cool Rubicon thing? am I an idiot for taking 4 months to figure this out?
Originally Posted by timberwolf0122 View Post
I think you are confusing the right to free speech with the right to be a **** bag, only one is protected by the constitution.
QuickSilverCon is offline   Reply With Quote
Old 03-09-2008, 09:20 PM   #2
03Wrangler
my 03 x can do it also... it's called the clutch switch defeat.... if you take the fuse out it will require you to use the clutch....
i chose to put the fuse in...
FOR SALE
Olympic Trunk for 03 TJ
03Wrangler is offline   Reply With Quote
Old 03-10-2008, 07:53 AM   #3
BlackBellamy
Yeah that Rubicon has a standard clutch bypass when in 4lo. If you wanted to do it for 2wd and 4hi you would have to mess with the fuses.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline   Reply With Quote
Old 03-10-2008, 03:37 PM   #4
madduc
Thanks for the tip! Just tried it today on mine, just wish I could always start it without the clutch.
05 Rubicon
madduc is offline   Reply With Quote
Old 03-10-2008, 04:47 PM   #5
BlackBellamy
You can - insert a 20 amp fuse into position #20 - that will bypass the entire shebang.
Old 03-10-2008, 07:43 PM   #6
madduc
I tried that. In mine location #20 has no connectors for the fuse to engage. Thought that maybe since I have cruise control that they don't allow it. Otherwise when the cruise is engaged and I push the clutch in, it would allow the engine to free rev.
05 Rubicon
Old 03-10-2008, 07:46 PM   #7
Luckyduck
so would putting the 20 amp fuse in position 20 make it for i did not need my clutch to start? my dads truck has a switch you push
Luckyduck is offline   Reply With Quote
Old 03-10-2008, 07:52 PM   #8
BlackBellamy
yeah - unless you have cruise control apparently or maybe it's an 05 rubicon thing i don't know - but that's what i did with my 99
Old 03-10-2008, 08:09 PM   #9
Luckyduck
ya i just dug through my bag of fuses found it put it in and it worked!!!! thanks a ton i was so mad i could not start with out the clutch!!!
Old 03-10-2008, 08:49 PM   #10
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
i'll have to try 4 low with out the clutch tomorrow.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 03-10-2008, 09:54 PM   #11
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
I wired a switch onto mine so I could turn it on or off. My wife drove my Jeep occassionaly and I had a son that was getting ready to drive - didn't want to take the chance. Of course had I found JF before I did the wiring I would've bought one of those fuse inserts that has wires coming out of it that you can attach a switch too - as it was I tapped into the wiring at the clutch pedal!
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 03-11-2008, 11:10 AM   #12
Bmel17
i have a 06 sport and there is a pressure loaded cylinder attached to the clutch. If you zip tie it back (best way I could think of) its bypasses the clutch as well. You can also get a relay to install that will do the same trick. I used the zips ties because they were free. plus now my remote start works.
Bmel17 is offline   Reply With Quote
Old 03-11-2008, 11:14 AM   #13
Luckyduck
i was happy i found the simple fuse fix that was free and i can now put in a remote starter!
Old 03-11-2008, 07:11 PM   #14
JeepRocks86
I tried it today in 4 low. NO go for my Sport.
My Build Thread.
For Sale:
Old 03-11-2008, 07:32 PM   #15
BYuen
Wahoowa
BYuen's Avatar
I'm gonna have to try that fuse thing. I was so frustrated the other day when I needed to shift in a puddle up to my headlights and couldn't
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Glock Forum
