Clutch about to go?? little help please - JeepForum.com
post #1 of 5 Old 08-21-2004, 06:21 AM Thread Starter
kevmccoy
I have a 98 with a little over 75000 on it and I think my clutch is about to go. I will be driving down the road and it seems to me like she just sort of slips out of gear and pops back in. It sort of bucks when this happens. It mostly happens in 3rd gear, I think it may have happened once in 4th but nothing else. I actually have no idea if it has to do with the clutch at all, I have never had a clutch go on me before. It would make sense however because my little sister has learned on it and drives is while I am at school, my girlfriend has learned on it, and I drive it most regularly. In addition to that I have no idea how the clutch was treated the jeep's first 60,000 because we bought it used. Any help or insight would be greatly appreciated.
-Kevin
kevmccoy is offline
post #2 of 5 Old 08-21-2004, 06:51 AM
Laila
Laila's Avatar
-Kevin
My guess is that your clutch is about to completely go out. My advice is to take it in or replace the clutch before you get stranded far from home. Mine went out on my 99 at 80,000 miles and I'm pretty hard on my clutch. But the same thing happened to me.
Good Luck!
99 TJ 4Banger
RE 3.5 SuperFlex
33in BFG Mud Terrains
member # 3
Laila is offline
post #3 of 5 Old 08-21-2004, 07:02 PM Thread Starter
kevmccoy
yeah, thats what I'm afraid of. Anyone else have similar problems or can tell my symptoms of your clutch about to go? Thanks!
kevmccoy is offline
post #4 of 5 Old 08-21-2004, 07:54 PM
papredator
papredator's Avatar
Try this, wind out third or fourth gear going up a hill and watch your tach. If the tach. races and you are losing power it most likely is the clutch. Good luck with it.
papredator is offline
post #5 of 5 Old 08-21-2004, 08:35 PM Thread Starter
kevmccoy
alright, I'll give that a try tomorrow. I haven't been looking at the tach when this happens so I dont know if it goes up a bunch or what. Thanks for the help
kevmccoy is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
