cluster lights not working - JeepForum.com
post #1 of 3 Old 10-04-2009, 11:28 AM Thread Starter
sniperx9119
ok so heres my problem, the last owner installed these stupid autozone type R leds into the gauge cluster...problem is they arent even hooked up..there fore i have no cluster lights at night..ive dug into it and i found a connector i think im supposed to wire to them..2 white 20-22gauge wires with a 2pin connector on the end..any idea where i gotta plug this thing in? and which is ground and which is hot? ones solid white and the other is white with grey - - - - -'s any help would be greatly appreciated, thanks!
sniperx9119 is offline
post #2 of 3 Old 10-04-2009, 12:13 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #3 of 3 Old 10-04-2009, 12:38 PM Thread Starter
sniperx9119
problem is they arent just bulbs...there actually little black led holders installed in the top of the gauge cluster facing down...
also installed a aftermarket radio...the dimmer need to be hooked up to make the back lights of the cluster illum?
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 06:51 PM
4wd Cluster Light Not Working Goose346 TJ Wrangler Technical Forum 23 01-14-2009 02:56 PM
Dashboard cluster quit working..... BringThaPain TJ Wrangler Technical Forum 14 08-12-2008 04:47 PM
my cluster quit working! yzman720 TJ Wrangler Technical Forum 10 03-23-2007 11:35 AM
92 YJ Instrument Cluster not working jeepgiant YJ Wrangler Technical Forum 8 09-01-2005 08:36 PM
