Quantcast Clunking in rear driver's side - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clunking in rear driver's side
Old 10-14-2008, 08:56 PM   #1
inutero1212
I have a 2000 TJ with a 3" lift and 33x12.50's not much else' recently I started hearing a clunking noise that i could feel in the tub of my vehicle. I started looking and saw my rear trac bar was loose, so i tightened it. then i noticed my front trac bar ball joint was junk. i replaced it and greased it. next i jiggled the drive shaft to test for u-joint integrity, and no play whatsoever. i can only now think that it may be a control arm or something of the sort. i jumped up on my back end and wiggled back and forth side to side and up and down and no noise, but when i accelerate from a stop or go from P to any gear fwd or rev, it makes a loud clunk. also to be noted i have and auto tranny. anything you can give me helps.
inutero1212 is offline   Reply With Quote
Old 10-14-2008, 09:09 PM   #2
lilman
Dude, I just had same problem and fixed it by tightening the 4 bolts on the transmission hump that hold the transfer case linkage to undercarriage and also I had a rear lower control arm that was a little loose. I could tell the arm was loose cause all around it on the control arm bracket was shiny where it was rubbing.
lilman is offline   Reply With Quote
Old 10-14-2008, 09:57 PM   #3
inutero1212
it is night here now, but a quick update from the drive home from the girlfriend's leads me to think that it might be the tranny as i was getting a more frequent clunk from simply driving on our crappy roads without the acceleration. in the morning i will check and post later that night.
Old 10-15-2008, 10:42 PM   #4
inutero1212
ok, i have all the intel i can gather before i start taking everything apart. The noise is usually when accelerating from a complete stop and more extreme when i am doing it while turning. while driving i can hear it only on small choppy bumps. I checked the tranny mount and it seems good. What do we have?
Old 10-15-2008, 11:11 PM   #5
thsydup
Take a look at your lower shock mounts.. the nuts may look tight, but if not properly torqued, the shocks will tap the stud during sharp acceleration (in forward & reverse).
thsydup is offline   Reply With Quote
Old 10-16-2008, 11:37 AM   #6
Xiled1
Junior Member
also check the tightness of any rear sway bar extensions. I get clunking from those shifting up and down.
06 Rubicon Unlimited, 6 speed, 4" lift, 1" BL, 1" BMML, Rancho 5000's, JKS frnt Track Bar, Rear RE TB, RE Control Arms, 305-70-16 KM2's. Tons of Armor.
Xiled1 is offline   Reply With Quote
Old 10-16-2008, 11:51 AM   #7
mdm
Farm Wheeler
Originally Posted by inutero1212 View Post
...I checked the tranny mount and it seems good...
How did you check the transmission mount? You can have a transmission mount that has completely separated and not be able to see it by just looking at it with it installed. Try jacking up the transmission a little and see if you get any separation in the mount.
Check your motor mounts also.
mdm is offline   Reply With Quote
Old 11-17-2008, 04:15 PM   #8
inutero1212
the problem was my U-joint on the front driver side of the axle for the record, thanks for the help.
Glock Forum
