clunking noise whenever I slow down. - JeepForum.com
post #1 of 9 Old 08-03-2010, 05:31 PM Thread Starter
calrain07
I was driving my TJ earlier today and I turned off the music. I noticed that when I'd slow down to a read light or to make a turn, there was a clunking noise. I don't have lockers at all so I know it can't be that. I can't pinpoint exactly where it's coming from. All I know is that it doesn't happen when i accelerate, even at low speeds, or when I'm on the throttle at all. Only when I let it move on its own or when slowing down to about 8 mph or less. Any ideas of what I should check?
'05 rocky mountain edition....kc daylighters, 33x12.5x15 Duratracs, RC 3.25" SL, and 1.25" Spidertraxes
calrain07 is offline
post #2 of 9 Old 08-03-2010, 05:33 PM
Apex
Recon death squad
Apex's Avatar
Bushings, motor mounts, ujoints, bolts.
Just get under the Jeep and start grabbing things and seeing if anything is loose. Then get a friend to drive your Jeep down the street and slow down when he approaches you so you can hear it from the outside...might help locate the noise.
Apex is offline
post #3 of 9 Old 08-03-2010, 05:33 PM
biffgnar
biffgnar's Avatar
Did you replace swaybar links when jeep was lifted? If not check the bushings on the links.
biffgnar is offline
post #4 of 9 Old 08-03-2010, 05:50 PM Thread Starter
calrain07
yea i did replace the links....im gonna go under there tomorrow since I don't have anything tomorrow. hopefully nothing serious
post #5 of 9 Old 08-03-2010, 08:21 PM
jeepinjohn72
U joint
Probably front axle u-joint or both (the ones out by the brakes) just did one of mine. Had a lot of slop in it and had the same symptoms you are describing.
Good luck!
jeepinjohn72 is offline
post #6 of 9 Old 08-03-2010, 08:27 PM
JRostron30
Crap transfer case. Happened to my dads truck a few weeks ago. Same issues really good thud after stopping - driving - all around.
I said my Jeep sit so high up
From tha floor
I feel like im an alien
In a ufo i goo eeaauu
Beam me up!
JRostron30 is offline
post #7 of 9 Old 08-03-2010, 08:29 PM
wavelength20
check the bolt torque on your suspension components to ensure they are at the factory recommended settings.
wavelength20 is offline
post #8 of 9 Old 08-04-2010, 03:56 AM
BlueFlame
BlueFlame's Avatar
NEVER turn down the stereo!
You hear all kinds of strange and scary things when you do that...
BlueFlame is offline
post #9 of 9 Old 08-04-2010, 08:21 AM
Streetbyker13
I agree with the axle shaft u-joints (by the brakes), sounds kinda like what mine was doing, but when they get real bad you hear them alot more. Also check your caliper bolts, I've seen those loosen up and make some noises kinda like that when the calipers start movin
Streetbyker13 is offline
noise , clunking , clunk , slow , stop , stopping , tj , wrangler
bad clunking noise in front when making sharp slow turn , like parking ?HELP chaznad TJ Wrangler Technical Forum 25 07-21-2011 02:22 AM
Clunking noise coming from front end on slow turns Ferret TJ Wrangler Technical Forum 14 10-24-2009 03:43 PM
clunking noise!!! 02tjwrnglr TJ Wrangler Technical Forum 2 02-05-2009 04:39 PM
Slow Speed Clunking Sound? TJShadow TJ Wrangler Technical Forum 13 11-09-2008 12:18 PM
clunking noise. need help tuc TJ Wrangler Technical Forum 3 05-13-2008 11:35 AM
