"Clunking" front end - JeepForum.com
post #1 of 10 Old 06-11-2004, 09:45 AM Thread Starter
porch13
porch13's Avatar
I have some weird clunks that I can feel and hear coming from, what I believe to be, the front left side of the Jeep. (It's a 97 Sahara, with a BB and BL/MML) They are definitely suspension/steering related. It's almost as if something is loose, but I can't figure out what. I greased all of the fittings up there the night before last and the clunking is now much more prominent. I've been under there and given everything a good tug and I can't really see or feel anything loose. Does anyone have a suggestion on how I can narrow down what the problem may be?
Thanks!
97 Black Sahara. 2" BB, 1" BL, MML, 32's.
porch13 is offline
post #2 of 10 Old 06-11-2004, 09:52 AM
Zim97tj
i had a loose sway bar link that i had to tighten it would make a clunk, you could check that it may be worn.
Inca Gold, re, bfg, psc, warrior, tmax, ar, rustys, okoffroad, etc.
Zim97tj is offline
post #3 of 10 Old 06-11-2004, 10:53 AM
EricS
Thanks!
My control arms clunk/pop all the time. I have the RE 3.5 SF kit. It took me a while to figure out what it was. When I did, I retightened them to spec and it went away. It came back, but I put off tightening them. They are now tight to spec, but still knock.
Also, I have heard of the T-case skid bolts being loose and doing the same thing. HTH
EricS is offline
post #4 of 10 Old 06-11-2004, 04:02 PM
Blackhole
I would also be very interested in any ideas on this problem, as i think i have the same problem. It only happens at slow speeds. usually when i am pulling into my driveway.
Black 97 TJ 5.2L V8 5.5" RK long-arm 36" IROKs
Red 79 Ford F-250 4x4 (tow rig)
Blackhole is offline
post #5 of 10 Old 06-11-2004, 04:13 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Definately check the swaybar links. My driver's side was loose making my jeep clunk at slow speeds under acceleration.
04JeepTJ is offline
post #6 of 10 Old 06-12-2004, 04:06 PM
ncb76
ncb76's Avatar
Yeah. The ball on the link pops out of the socket, but it is covered by a rubber boot, so it can be hard to see until the boot rips. Get a friend to rock the Jeep back and forth while you look underneah. That might help. or you can jack the front end up and let the axle droop. If it is the sway bar link, it should pop out.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #7 of 10 Old 06-12-2004, 07:24 PM
KUK9
KUK9's Avatar
I was trying to figure that exact sound out myself. I had posted earlier, but I don't think I was specific enough with my question. I have the exact same sound coming from my front end, and I haven't been able to find the culprit either. Now I have some good starting places. Thanks for saving me some hassle!!
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #8 of 10 Old 06-12-2004, 09:54 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
My swaybar link's bottom t-55 bolt wasn't tightened enough (by me). It eventually worked itself loose enough to clunk. I have heard of the upper portion breaking like ncb mentioned but mine werent - well if they were then the dealer didn't tell me and just replaced them
04JeepTJ is offline
post #9 of 10 Old 06-13-2004, 12:14 AM
WAMPAROO
Thats EXACTLY whats been goin on with me - I just noticed it when the rubber boot ripped...so now its just kinda disconnected - I was thinking about just taking it out and adding JKS but are there any parts broken that ill need to reuse when putting in the disconnects?
WAMPAROO is offline
post #10 of 10 Old 06-13-2004, 10:32 AM
AjRagno
Definitely check your sway bar links.
My front end has been clunking for awhile. This morning, I thought the link seemed a little loose so I jacked up the driver side front end and the ball popped out of the socket. When I let the jack down, it made a very familiar clunk.
After removing the links from the sway bar I went for a drive and didn't hear anymore clunking.
AjRagno is offline
1997 TJ -- Rear Wheel "Clunking Noise"...??? tank29 TJ Wrangler Technical Forum 15 06-10-2011 06:12 PM
Something is "clunking" when I turn right traderdan JK Wrangler Technical Forum 10 10-13-2009 07:21 PM
Is This "clunking" Sound Normal??? MrKing TJ Wrangler Technical Forum 5 05-25-2009 08:15 PM
Rear spring is "clunking" NYwranglanator TJ Wrangler Technical Forum 19 06-16-2006 10:18 PM
HELP...rear end sounds "loose" -clunking noise ninjajeep TJ Wrangler Technical Forum 6 10-17-2004 11:12 PM
