"Clunk" noise when making a left turn. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > "Clunk" noise when making a left turn.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 04-30-2009, 12:03 PM   #1
BloodThirsty
Seems to be coming from the front passengers side. It doesn't do it on every left hand turn but every once in a while. So what should I check? What could it be?
BloodThirsty is offline   Reply With Quote
Unread 04-30-2009, 12:06 PM   #2
JBTJ
My trackbar bolt was loose. I really had to crank down on it to go away. Thought I was going to break the bolt.
JBTJ is online now   Reply With Quote
Unread 04-30-2009, 12:07 PM   #3
Chester405
check your sway bar and make sure that is is not broken or binding. i know that mine was binding cause it was shifted over to one side of the jeep so when i made a turn, it would pop.
Chester405 is offline   Reply With Quote
Unread 04-30-2009, 12:44 PM   #4
ajamison
SWAG
ajamison's Avatar
1991 MJ Comanche
also check the swaybar bushing, it might be worn out or shredded. i had the same problem.
Jamison
- I do gears, message me for details!
1991 Backwoods Comanche Build
2005 Dodge Ram Cummins Tow Rig
ajamison is offline   Reply With Quote
