Clunk and Bang I go.. - JeepForum.com
post #1 of 18 Old 11-08-2010, 02:22 PM Thread Starter
all3forus
Few weeks ago. The rear end started to clunk and bang when shifting between gears. I pulled the diff cover off and looked for damage. Did not see any damage.
Checked u-joints and drive shaft, everything tight.
How do i check pinion for looseness and play?
I'm thinking it is a bearing in the pinion.
all3forus is offline
post #2 of 18 Old 11-08-2010, 02:25 PM
MO2500
Grab the pinion yoke and try to shake it back and forth. There shouldn't be any play there. Could also be carrier bearings and your backlash has opened up.
You sure it's coming from the rear end?
Instagram: @omsmike
MO2500 is offline
post #3 of 18 Old 11-08-2010, 02:52 PM Thread Starter
all3forus
Yes I am sure. It only does it when you take the load off during shifting.
I checked all my bolts on the suspension for torque and movement of bushings.
I just went out and checked pinion. It did not move much. I jacked it up and took the load off drivetrain.
post #4 of 18 Old 11-08-2010, 03:01 PM
MO2500
Shouldn't move at all side to side. Rotation is okay unless it's excessive. That would point at an issue inside the rear end.
Instagram: @omsmike
MO2500 is offline
post #5 of 18 Old 11-08-2010, 03:14 PM
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by mo2500 View Post
shouldn't move at all side to side. Rotation is okay unless it's excessive. That would point at an issue inside the rear end.
x2
wushaw is offline
post #6 of 18 Old 11-08-2010, 03:21 PM Thread Starter
all3forus
It does move from side to side. Looks like it is going in the shop.
Thanks for the help
post #7 of 18 Old 11-08-2010, 03:37 PM
MO2500
Make sure it's a reputable shop that has experience with ring and pinion setup and setting pinion bearing pre-load with a crush sleeve. Someone that will back up there work if something were to go wrong in the first few thousand miles after would be preferred.
Instagram: @omsmike
MO2500 is offline
post #8 of 18 Old 11-08-2010, 03:42 PM Thread Starter
all3forus
I did find a shop here in town that does good work..They are called Six States Dist..
post #9 of 18 Old 11-08-2010, 03:45 PM
TJLover99
I say pop that rear end open and see what you can see.
If it were easy, everyone would do it
TJLover99 is offline
post #10 of 18 Old 11-08-2010, 03:46 PM
AngusTJ
Also, check your UCA and LCA bushings as you accelerate because i had similar symptoms and this was the burden. Perfect excuse to install my adj control arms
"Run what ya brung and hope ya done brung enough"
Originally Posted by pjleslie03 View Post
I know how bad the D35 is in the rear, but would it be bad to have one in the front?
Originally Posted by Lostj View Post
yes, you wouldn't be able to steer
98' TJ, 4" Superlift, JKS 1.25" BL/ 1" MML, 8k Gorilla winch, Cowl intake, D30 Aussie, shafts/D44 Powertraxx, shafts (4.56's), Rusty's Adj CA's front/ RE Adj CA's rear, Recessed tails, sway discnct'd, 152 db train horns, 34x10.5 LTB's Amer Rac/36x13.5 Irok's Streetlocks, Grenade shifter, Pioneer deck/speakers, Warn bumpers, KC upper lite mts/Slim lites, EBC yellows, 40 series Flowmaster, couple tasteful more ...
AngusTJ is offline
post #11 of 18 Old 11-08-2010, 03:59 PM
MO2500
He already popped the cover and checked (look at first post) and he already checked his CA bushings (also first post).
There is play in the pinion and that is most likely the issue. That needs to be addressed for sure.
Instagram: @omsmike
MO2500 is offline
post #12 of 18 Old 11-08-2010, 04:02 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
He has a D44, no crush sleeve...
Knuckelhead is offline
post #13 of 18 Old 11-08-2010, 04:06 PM
MO2500
Good catch. I assumed D35 and shouldn't have
Instagram: @omsmike
MO2500 is offline
post #14 of 18 Old 11-08-2010, 04:07 PM
TJLover99
My bad... probably should read more carefully next time.
post #15 of 18 Old 11-08-2010, 04:14 PM
Imped
Imped's Avatar
Tighten that pinion nut down to ~180 lbs before you take it in anywhere. And make sure the control arms are torqued down real good as well. Even then, bushings suck. They may be worn out and allowing too much movement.
OlllllllO
IndyORV
Imped is offline
Bang\Clunk noise from rear ...help. SXti TJ Wrangler Technical Forum 40 11-02-2009 09:48 AM
Your Jeep may start off with a bang, well Mine starts with a clunk... disarm6565 YJ Wrangler Technical Forum 4 06-20-2008 10:54 AM
Shift Clunk/Bang Thump85 TJ Wrangler Technical Forum 8 03-03-2007 12:03 PM
Clunk/bang when shifting or accelerating hard jfandem TJ Wrangler Technical Forum 6 08-23-2004 10:55 AM
boom,clunk,bang AX-15 gone nutterbetter YJ Wrangler Technical Forum 8 04-26-2004 10:26 AM
