Clockspring suspected dead - JeepForum.com
post #1 of 7 Old 09-01-2008, 08:11 PM Thread Starter
Wrangler_91
Since I got my jeep last March the airbag light has been on as well as the fact that my horn doesn't work. i've checked fuses and everything is good. I was reading a thread the other day and someone mentioned that having dash lights and problems come up and be a symtom of a bad clockspring. Any way to test this theory that my clockspring is bad other than buying a new one and trying it out? Don't want to spend $100 if it not needed. . If not any other suggestions on things that could be going on.
One odd thing I have noticed is that when I press on the center of my wheel (where the airbag is) the plastic goes back about half and inch roughly as if there is nothing supporting it. I don't know if this is normal or not. My airbag is there though and it is plugged in. My jeep is a 98 TJ.
Wrangler_91 is offline
post #2 of 7 Old 09-01-2008, 08:52 PM
03Wrangler
03Wrangler's Avatar
2010
sounds like a clockspring to me... get it wet?
03Wrangler is offline
post #3 of 7 Old 09-01-2008, 08:57 PM
dbbd1
dbbd1's Avatar
Where/what is the clockspring?
dbbd1 is offline
post #4 of 7 Old 09-01-2008, 09:26 PM
EagleStorm
2008 WK
Are you sure the air bag is there? maybe it was crashed and the did not replace it just made it look that way? could be why the light is on. Disconnect the battery wait 2 or 3 min remove the air bag see if it is pluged in?
does it look like it has been recoverd? if the bag is realy there and its pluged in it's most likely the clock spring. I bring up all this because you said it's been on since you got it. the clock spring is behind the air bag in frt of the multifunction switch round has yellow connector connects to the air bag with a 2 pin small connector becareful removing it if you break the connector you will have to replace the clock spring
EagleStorm is offline
post #5 of 7 Old 09-02-2008, 04:30 AM Thread Starter
Wrangler_91
Yes the air bag is there. I removed the cover after disconnecting the battery and confirmed that it was there and that it was plugged in. It was like this when I got the jeep so its possible the P.O. left it out in the rain and got it wet. Is there no way to test it though to make sure it is the clockspring?
post #6 of 7 Old 09-02-2008, 10:37 AM
EagleStorm
2008 WK
you can unplug all connectors to the clock spring and run an ohms test there are connectors ft and rear of it 2 in back i think and the one if that connects the air bag
post #7 of 7 Old 09-02-2008, 10:46 AM
fisher836
fisher836's Avatar
are you throwing an engine code? TPS code specifically?
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
Check engine light on, suspected misfire...Already serviced 2 days ago for this... Mudpuppy09 TJ Wrangler Technical Forum 16 04-16-2009 08:05 AM
clockspring talltree TJ Wrangler Technical Forum 5 01-07-2009 07:15 PM
clockspring jeepingcons TJ Wrangler Technical Forum 4 11-06-2008 08:50 AM
TJ Clockspring? Terrain Twister TJ Wrangler Technical Forum 6 06-12-2007 07:59 PM
clockspring? AJEEPB TJ Wrangler Technical Forum 1 06-26-2004 08:35 AM
